Sponsored by: Real Truck
Are 05-2016 front axles interchangeable?
Old Aug 3, 2025 | 08:55 AM
isaac728's Avatar
isaac728
6th Gear
Hello, I have a 2012 F250 extended cab shortbed with the 6.2 2wd. I’d like to swap it to 4x4, but I’m having a hard time finding a 11-16 axle in my area. Are 05-10 axles the same?
Would there be differences that I can remedy such as bearings from a 2012 axle that I could put in an 05 axle and such?
thanks!
Old Aug 3, 2025 | 07:18 PM
ifrythings's Avatar
ifrythings
They are pretty much the same from 05-16, there are some differences though.
05-07 use a different swaybar end link
08-12 are the same (ABS sensor may have changed in 11)
13-16 got bigger brakes so rotors, pads, calipers, caliper bracket and knuckle are different
Soft brake lines change over the years, just get the correct ones for your truck, track bar mounts (on the frame) change each generation so you’ll have to get one for 11-16.
Everything else is the same between years, just make sure to get the same ratio as your rear axle.
Loganbrown22
Jan 21, 2025 11:05 PM
mjsnodgrass
Jul 6, 2024 08:43 PM
Schickel
May 5, 2013 06:34 PM
Highboy74
Ford Truck Parts for Sale
Feb 2, 2012 09:08 PM
