Sponsored by: Real Truck
axle swap
Old Jul 6, 2024 | 02:16 PM
mjsnodgrass's Avatar
mjsnodgrass
axle swap
my rear axle is junk. the carrier bearings race spun in the housing. will a S409H axle interchange with a S406E ? thanks for the help
Old Jul 6, 2024 | 03:08 PM
ifrythings's Avatar
ifrythings
You’ll get better help with truck year/motor/front/rear/drw/srw for both axels vs some unknown number molded into the casting.
Old Jul 6, 2024 | 06:44 PM
mjsnodgrass
both of those numbers came from the top line on the tags bolted to the rear cover. the numbers on the bottom line indicate gear ratio / limited slip / and date of manufacture from what i understand. is there a different model number i should be using for interchange? the truck in question is 1999 rwd with auto and 7.3 diesel. thanks
Old Jul 6, 2024 | 08:08 PM
ifrythings's Avatar
ifrythings
99-04 f250/f350 and 99-05 excursion 2wd/4x4 rear axles will work, early 99 trucks had one brake calliper flipped but doesn’t matter for a swap.
The axle code on the door jam will be what you want to compare if you want the same axle or one with a different gear ratio or limited slip, an axle code with two numbers in it will be an open diff, one number and a letter will be limited slip, the number crosses over to what gear ratio it is.
05-10 will bolt in and have bigger brakes but require bigger rims (17” minimum), different offset rims so they don’t stick out 1-1/2” on each side, abs sensor on the diff needs to be swapped to the older 04-earlier sensor and the e-brake lever will need to be changed to accept the older e-brake cables.
Old Jul 6, 2024 | 08:43 PM
mjsnodgrass
perfect. just the information i was needing. thank you very much
Itzkriss
Jun 18, 2023 10:35 AM
kidkyle21
18
Apr 18, 2014 09:48 PM
Twistedtesty
May 24, 2010 09:58 PM
james.mcafee1
Mar 16, 2010 08:32 AM
