Voltage regulator?
Old Jul 14, 2025 | 01:46 AM
SkeleCog's Avatar
SkeleCog
8th Gear
Voltage regulator?
Guys on fb said this is a voltage regulator(next to solenoid)i could see that being the case but every other one ive seen on the fords I've owned looks much different. Question is, is that what it is and what is the yellow wire? It runs all the way into the cab under the dash on drivers side and is not hooked up to anything really more curious that anything.
Old Jul 14, 2025 | 03:56 AM
Truckwardo's Avatar
Truckwardo
Voltage regulator. If it's not charging change it.
Old Jul 14, 2025 | 04:28 AM
SkeleCog's Avatar
SkeleCog
8th Gear
It charges fine its always on the high side according to the guage I usually just test with the multimeter but I wonder what that yellow wire is for. Is it stock or some random regulator.
Old Jul 14, 2025 | 04:48 AM
Truckwardo's Avatar
Truckwardo
It's factory. The yellow wire would go to a dash light or to a gauge to show voltage i think.
Old Jul 14, 2025 | 09:53 AM
ihc1470's Avatar
ihc1470
I agree it does not look like any external mount Ford regulator that I have seen. They use a 4 terminal push connector. This looks to use terminals with screws. My guess is this is a relay.
Old Jul 14, 2025 | 03:53 PM
SkeleCog's Avatar
SkeleCog
8th Gear
that's what i was thinking,im gonna follow the wires see if it leads anywhere i had a few guys on fb say old style horn relay...
Old Jul 14, 2025 | 06:29 PM
SkeleCog's Avatar
SkeleCog
8th Gear
it is a horn relay, just confirmed it. Thanks for the help guys.
crank1000
Jul 31, 2024 01:30 PM
Diymechanicmike
Large Truck
Sep 4, 2022 01:29 PM
maple sapper
Aug 10, 2013 07:01 PM
2xcrash
Nov 8, 2008 10:23 PM
Matt_W
Electrical Systems/Wiring
Dec 30, 2003 04:42 PM
