Should I change fuel filter e350
Old Jul 14, 2025 | 12:17 AM
Bobby Detecting's Avatar
Bobby Detecting
Hello everyone have had my 2008 ford e350 since 70k miles have 276k on it know and it just occurred to me never have changed the fuel filter is that something I should do is it something a non mechanic with basic knowledge can do myself. It also occurred to mean when acceleration I notice a delay like not having the get up and go acceleration that it once has 5.4 2 valve. Could be that I have never changed the fuel filter? Thanks
Old Jul 14, 2025 | 06:31 AM
manicmechanic007's Avatar
manicmechanic007
Your fuel filter is part of the fuel pump and is not part of a normal service schedule
Just replace the complete pump when it fails
Dodge started that crap back in 1995-96 with their Ram trucks IIRR
The engineers that came up with that should be castrated
Old Jul 14, 2025 | 06:50 AM
econo93's Avatar
econo93
After 276k I wonder what the fuel pressure reads?
Old Jul 14, 2025 | 08:09 AM
Johnny Paycheck's Avatar
Johnny Paycheck
I wonder what the compression readings are on all eight holes at that mileage.
Old Jul 14, 2025 | 08:41 AM
manicmechanic007
Change the oil regularly and tune them up
Then, the 2 valve 5.4 motors will go 400k
I sure would not go on vacation (or long trip) without replacing the fuel pump
You keep one full of gas and the pump will go 300k+ on a duty cycle system
Good job
Old Jul 15, 2025 | 10:23 PM
E350 S's Avatar
E350 S
5th Gear
try replacing the module
Old Jul 18, 2025 | 03:22 AM
Bobby Detecting
Fuel filter
Glad I replaced it used a oem metal canister filter old one was full of varnish and grime and dirt don't don't if the fuel pump has a filter but there is definitely an external metal canister filter on the ford rconoline vans.
Old Jul 18, 2025 | 05:57 AM
manicmechanic007
2008 was the cutoff date for in tank v/s frame rail filters
If yours has an external filter
Be glad you have the earlier style
Old Jul 20, 2025 | 10:26 AM
Bobby Detecting
Fuel filter
Yes it is a 2008 so the fuel filter is located on the frame.
Hellkamp
Oct 20, 2024 12:45 PM
Ltngdrvr
Jan 29, 2022 02:47 PM
ztodd377
15
May 29, 2021 10:12 AM
mattpowerstroker
Jan 16, 2008 07:43 PM
RoyalFord
1997 - 2003 F150
29
Aug 21, 2004 02:52 PM
