my axle pivot bushing is twisted. The axle beam is twisted. When I unbolt the radius arm it sits straight. Why I think radius arm is bent.
I think you should post a picture
Radius rods are strong as hell
Means there is just about NO way your rod is bent and the bushings are still good
I read the post and think you have NO problem
They are All on a bind
That's why the pivot bushings wear on an angle
