Heater fan control switch
Old Jul 13, 2025 | 07:54 PM
nutter3's Avatar
nutter3
Hello, I'm doing a complete rewire in a 1975 using Centech harness. I only have the fan running in the high switch position with it all hooked up.
During diagnosis, I have supplied 12v going directly to the resistors and fan (bypassing the switch) and i do have low medium and high as it should be. I have taken apart 2 different switches that i have, as neither one had continuity between 12v and low and medium( when in those or any switch position.) These are fairly simple switches, but I cant seem to get low and medium working. Ordered a new one from dennis carpenter.
Im just hoping someone can confirm if I've got the right idea on this problem.
Old Jul 13, 2025 | 08:53 PM
dlburch's Avatar
dlburch
or you could have your 12v and High speed wires swapped. do you have continuity between the pole marked High and medium/low?
Old Jul 13, 2025 | 10:21 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
All I got...
Old Jul 14, 2025 | 11:38 AM
nutter3's Avatar
nutter3
Thanks. I have the 12V going to the bottom connector that is perpendicular to the other 3. Pretty sure this is correct.
there is continuity on the switch between hi and medium only when in the high position. No other continuity in any positions other than hi. Hoping the new switch is good.
I know the resistors and wiring from switch connector to the fan are correct.
Old Jul 18, 2025 | 09:07 PM
nutter3's Avatar
nutter3
dlburch for the win! Thank you.
Centechs instructions are wrong. They have the 12V and Hi wires swapped on their drawing. This is the correct setup.
Old Jul 20, 2025 | 12:36 PM
nutter3's Avatar
nutter3
Just in case anyone else is installing a Centech harness, this is their instruction sheet for the heater that is incorrect. They have the hi and 12V in swapped.
F J
Nov 30, 2022 07:55 PM
jvmcc
Aug 13, 2016 02:38 PM
97-psd
Jun 11, 2008 07:04 AM
earl964
Feb 12, 2008 05:31 PM
intimidator7393
Dec 11, 2003 01:48 PM
