Escape & Escape Hybrid Ford Escape, Ford Escape Hybrid, Mercury Mariner, Mazda Tribute
AC turns off when its hot outside
Old Jul 8, 2025 | 10:12 AM
Scott McCoy's Avatar
Scott McCoy
Hi All,
I'm trying to troubleshoot my daughter's 2009 Escape Hybrid's AC system. It works well until it gets 80 degrees + plus outside and then it will turn off. Me and a local garage have both checked refrigerant level and it is where it should be. I know basics of AC but this has me stumped and I don't know what to else to check. Any suggestions?
Old Jul 8, 2025 | 05:21 PM
PupnDuck's Avatar
PupnDuck
Need to have a bit more information.
When you say it "turns off", do you mean the fan stops or does the fan keep blowing but the compressor clutch won't engage?
Is the engine at normal operating temperature when this happens and not running hot?
When the shop checked refrigerant level was the A/C running and putting out cold air and did they check both high and low side pressures?
Old Jul 8, 2025 | 06:41 PM
Scott McCoy
"When you say it "turns off", do you mean the fan stops or does the fan keep blowing but the compressor clutch won't engage?"
fan stays on but the compressor clutch disengages
"Is the engine at normal operating temperature when this happens and not running hot?"
normal temp
"When the shop checked refrigerant level was the A/C running and putting out cold air and did they check both high and low side pressures?"
yes he tested both
Old Jul 9, 2025 | 06:33 AM
projectSHO89's Avatar
projectSHO89
First thing I'd do is check for an excessive compressor clutch gap. If the gap is excessive, the clutch can drop out when the coil gets above a certain temp as the electromagnetic force weakens, and the clutch won't engage again until the system cools back down.
If the gap is okay, a scan tool will likely be needed to see if the PCM is commanding the clutch off for some reason.
FordPickMeUp
May 25, 2022 02:32 PM
bnovak
Aug 1, 2009 10:54 AM
wipper
Sep 16, 2004 10:33 PM
mrteegee
Feb 7, 2004 09:28 PM
galaxie223
Jul 31, 2003 09:20 PM
