Starter upgrade
Old Jun 30, 2025 | 04:50 PM
Gjorgjija's Avatar
Gjorgjija
Starter upgrade
Dumb question.
Does PM 9050 also has connection for 3 wires? On any photos that I found on the internet, I can see only 2 connections (one for battery cable, and one for small wire). Original starter motor has 2 cables and 1 wire.
Old Jul 1, 2025 | 08:32 AM
gespeter's Avatar
gespeter
My 93 NA has 2 connections:
one from solenoid (actually a "contactor" / "relay") on fender
one big cable to battery
However, the only true "solenoid", on the starter, has 2 terminal bolts, one of which is connected to the motor inside and no cables should be attached to that one.
Reminder to be very careful that cable and wire going down to starter are properly routed do as not to chafe or melt and short to frame.
Fuel line runs right through there and if battery cable got shorted down there it could burn through fuel line and start a fire at the same time your batteries were exploding. Fuel would be gravity fed and it would continue to burn for as the battery acid ate through everything.
I'm just sayin
BrooklynJoe
Feb 17, 2013 02:30 PM
BostiPB
1978 - 1996 Big Bronco
May 25, 2011 09:29 PM
david00f150
Jun 6, 2006 04:16 PM
cjf5150
31
Mar 17, 2006 05:47 PM
MichiganBill
Electrical Systems/Wiring
May 22, 2003 07:32 AM
