no start issue
Old Jun 23, 2025 | 07:56 AM
JCJ6338's Avatar
JCJ6338
4th Gear
no start issue
I have a no start issue with my truck. when i turn the key to the on position all is normal. When i turn the key to the crank position no power goes to the solenoid ignitor wire. I have checked the actuator rod and it moves as it should, I have removed the ignition switch to inspect and it appears intact and not separated. After visible inspection I reinstalled switch and adjusted to ensure that the rod is pushing it all the way and it is. I can jump the solenoid and the truck runs and operates as it should. I have seen other posts with the same or very similar issue and never see the final diagnosis posted... Any one with similar issues or experience please chime in.. My initial thoughts are the ignition switch, or the neutral safety switch.. any other ideas before i start throwing parts at this truck? trouble shooting tips?
original factory truck.
87 f150 xlt lariat 4x4 shortbed
5.8 engine
carbureted truck
C6 Trans
Old Jun 23, 2025 | 08:48 AM
My4Fordtrucks's Avatar
My4Fordtrucks
Yes. You should have done more than look at the switch. I would have used a screwdriver to operate the switch to see if the truck started. If not I would have then tested the switch with a test light or multimeter.
Old Jun 23, 2025 | 09:01 AM
JCJ6338's Avatar
JCJ6338
4th Gear
I left the bezels off and column lose so i will do that this evening.
DinoD
Mar 15, 2024 04:04 PM
beckman
Aug 19, 2013 09:50 PM
chrisginco
22
May 14, 2013 12:17 AM
Artbo
Sep 9, 2005 06:39 PM
EdsonFarm
May 17, 2004 09:33 PM
