Engine Won't crank
Old Aug 21, 2005 | 03:38 PM
Artbo's Avatar
Artbo
Engine Won't crank
86 F-250, 460 auto trans.
Won't turn over.
Batt good, Starter good.
Used a remote switch at the solenoid started right up.
Adjusted neutral safe switch.
Replaced ignition switch also.
Any ideas?
Old Aug 22, 2005 | 06:31 PM
ScottInTexas's Avatar
ScottInTexas
Give me coffee - Or beer!
When you replaced the ignition switch did you check the rod that engages it from the key? Maybe an 86 doesn't have it. But on my truck (84) there is a rod that runs from the column at the top down the to ignition switch on the collumn under the dash. Maybe the end is broken and the rod is not pushing the switch at all. Check the continuity of the ignition wire going to the solenoid. Also, remove the ignition wire from the solenoid, turn the key to start and you should be getting 12 volts at the wire. Of course, make sure you have a good ground on the other lead of your meter.
Old Aug 22, 2005 | 08:54 PM
Artbo's Avatar
Artbo
Engine won't crank
Yeah, I made sure that the rod to the ignition switch was operational.
Wasn't easy in that cramped space. Plus the spring in the ignition switch moves the key back to the run position.
Checked for voltage at the start wire on the solenoid, with a good ground.
Nothing.
I did notice I have no reverse light and the dang thing popped out of park when I was monkeying with the neutral safe switch and linkage.
The dealer gets it tomorrow. Which really hurts my pride and pocket book.
Old Aug 23, 2005 | 07:28 AM
Icicle's Avatar
Icicle
You dont need to take it to a dealer for this, we can help.
do you mean you used a jumper wire on the solenoid and it fired up?
Welcome to FTE by the way
Hey Rollie...... see I told you id post in here more often
Old Aug 23, 2005 | 07:48 AM
82F100SWB's Avatar
82F100SWB
Sounds like your neutral safety switch is gone. Espically since your backup lights are also dead.
Old Aug 23, 2005 | 05:57 PM
ScottInTexas
Yes! Put your shifter into neutral and try starting, into park and try starting. Replace the neutral switch. You'll save lots of money and the hassel of dealing with dealers.
Old Sep 5, 2005 | 10:15 PM
wranglerastro's Avatar
wranglerastro
If when you tried to start and you hear a low thud or click at the starter solenoid but no start then you need to replace starter solenoid even though it seemed to work because you hear it click. The contacts may be bad and not conduct enough power to the starter. I changed mine and everything was ok.
Old Sep 9, 2005 | 06:39 PM
StillaKilla187's Avatar
StillaKilla187
Ya I just went through this exact same thing it is just the starter relay (solonoid) even if it clicks it still crapped out its only a 15 dollar part try that before bringing it to some gay dealer
Fordseventhree
Sep 11, 2014 10:45 AM
Bandit91
Mar 12, 2012 11:36 AM
modfan
Escape & Escape Hybrid
Nov 25, 2010 11:34 PM
Krazy351w
Aug 30, 2010 05:20 PM
THREEBROTHERS
2004 - 2008 F150
Aug 17, 2009 06:40 AM
