Turn Signal/Stop Light
Old Dec 6, 2003 | 12:22 PM
mikeal's Avatar
mikeal
I have a 99 EXP and the left rear turn signal and the brake light are both not working. The light bulb checked OK. I can't seem to find the blown fuse that could be causing this. Any suggestions where to start looking?
Old Dec 6, 2003 | 08:26 PM
MisterCMK's Avatar
MisterCMK
Can you read voltage when the turn signal, or brake is applied?
Old Dec 6, 2003 | 10:40 PM
PaulC's Avatar
PaulC
Is this bulb dual filament? Did you check by replacing the bulb with a new one?
Old Dec 7, 2003 | 12:58 AM
mikeal's Avatar
mikeal
I've replaced the light bulb but it didn't fix the problem. There's no voltage when turn signal is engaged. I don't have an owner's manual and I didn't feel like checking every fuse in the fuse panel box.
Old Dec 7, 2003 | 02:45 AM
PaulC's Avatar
PaulC
go to www.fordvehicles.com and enroll in "My Ford" This free service includes adobe (.pdf) files of documents including owner's manuals.
Old Dec 7, 2003 | 03:00 AM
JoLEE55's Avatar
JoLEE55
I have a Ford truck but I actually had something similar happen on my sable - actually all my stop lights and signal lights lit and wouldn't go off regardless of anything I pressed unless I took out the fuse. Turns out there was a device connected to the arm of the break pedal that is a sensor for breaking that turns the break lights on with the depression of the pedal and it went bad. I fixed it myself with the part from Mercury. May or may not be something you might want to check on.
Old Dec 7, 2003 | 07:33 AM
ftcaveman's Avatar
ftcaveman
Turn signal inop
I dunked the boat yesterday, and shortly thereafter found that I no longer have turn signals on my 1997 Explorer, even with the trailer disconnected. I examined all 427 fuses that I could find, but they appear to be good. A little frustrated, because the manual has no info regarding which fuse does what, and the fuse box has See Owners Manual under the cover.
Oh, I replaced my flasher module about a year ago with an aftermarket model -- it was three pin vs. the 14 pin I pulled out from the factory. Never had any trouble with it until now though, so I suspect this isn't part of my problem.
I tried going to FordVehicles.com to search, added an account, went to MyFord, etc, but I could not get any more information other than how to browse for floormats for a new truck. You would think that 'search' would return at least some sort of clue for stuff like this.
I am frustrated -- if anyone has this information, please post where it can be found.
Thanks in advance,
-kevin
Old Dec 7, 2003 | 10:39 PM
PaulC's Avatar
PaulC
www.fordvehicles.com; then
My Ford; then
Login: then
Look at the left side of the page at the green bars. Click Resources and References; then
Owner's Guide.
Old Dec 8, 2003 | 05:04 AM
ftcaveman's Avatar
ftcaveman
Thanks Paul, I must have overlooked it when I was searching yesterday. Unfortunately, it wasn't either of the fuses related to the turn signals (fuse 21/22). I suppose that I will have to change the flasher again. Come to think of it, last check-up I had, the four-ways weren't working, so maybe the 3-pin flasher doesn't have enough functionality to hack the mission. It seems strange that the flasher would go out before one of the fuses would. A design flaw perhaps?
Old Dec 8, 2003 | 08:17 AM
nickalbu's Avatar
nickalbu
I had an 00 expy and the left turn signal went out on my boat trailer. The truck lights worked fine so I spent about two weeks chasing a problem on the trailer. Even re-wired the entire trailer.
The I looked in the manual.......separate fuse for trailer turn lights....MAN I felt dumb.
Old Dec 8, 2003 | 08:40 PM
ftcaveman's Avatar
ftcaveman
That is pretty funny -- I am hoping to have an answer for this soon -- I am tired of driving without turn signals. Of course, being in West Palm, I mix in well now with all of the New York drivers. :-) I will pick up a flasher module probably tomorrow and see if that solves it -- any good reason why I should get the one with a whole bunch of pins, rather than the three pin variety?
Old Dec 10, 2003 | 09:05 PM
ftcaveman's Avatar
ftcaveman
Hello? Is anyone out there?
Old Jan 8, 2005 | 11:34 AM
bdwaustin's Avatar
bdwaustin
This thread is likely a big cob web by now, but thought I might try and hit it up for some help. I too recently noticed a left tail light (turn signal and brake) stop working on my 99 Expy. Did you end up finding the issue with yours? Was it a fuse?
Old Jan 8, 2005 | 01:19 PM
bdwaustin's Avatar
bdwaustin
Well, fixing my issue was easy nuff. It turned out just to be the dual fillament bulb.
BigCountry1978
15
Sep 3, 2025 08:33 AM
dmarsh2400
Aug 19, 2019 03:23 PM
Hwklein88
46
Nov 7, 2016 04:55 AM
irlfan360
17
Jun 3, 2015 01:18 PM
Duke78
Jan 17, 2010 04:58 AM
