turn signal doesn't work when lights are on
The following users liked this post:
Not a pro...
My best guess is that you have a ground somewhere. Did the lights and signals use to work together? Have you taken any fuses or connections/wires apart? Or did it just happen? If it just happened the. 90% sure it is a ground somewhere, you have to do a little bit of testing to figure out though. If you took it apart then double check all the wires. Make sure when you are testing that you have the lights and the signals on. Hope this helps
it means your grounds aren't grounding. When you have a good ground, current will flow through the light and into the chassis. The fact that there is no difference with them disconnected means you are not getting current flow to ground.
Use sandpaper or similar to clean up the contact area so that you get good conduction through the connections. (Both in the socket where the bulb bottom sits, and where the ground connects to frame.)
Nope. It only takes just a fraction of an ohm to bugger things up completely, and these circuits draw way too much current for an ohms test to be of use. Rust and corrosion is the enemy of these old (and new) Trucks.
You CAN use a voltmeter though, while the circuit is under load. Called a "voltage drop" test. This is one of the easiest, most effective skills to learn. Wish I knew about it when I was 17.
http://www.aa1car.com/library/voltage_drop_testing.htm
You can bet that the ignition and accessories in your truck aren't getting a full measure either, by the symptoms you describe. That's how it works. As a general rule, replace ALL the grounding cables once they reach 20+ years or so, grind down to shiny bright metal at the block, firewall, and frame.
The headlights and turn signals use the frame as part of the return path. This is the likely culprit (or part of it). Oftentimes after engine or transmission work, someone will forget a ground strap or leave it loose, etc. Very common problem. This can cause other problems too. During engine starting maybe 250 amps are drawn in an instant, if the normal engine ground path is not there an alternative route will be used, through things not designed to carry current.
Brake lines. Fuel lines. Throttle cables, wheel bearings, gears, etc. These will even get red hot, not fun. Good grounds are important for Happy motoring!
You are not alone
I had a similar situation. Lights off - signals worked fine. Lights on - only one side would flash, the other side would be a solid dim light and the indicator light on the dash would not light up at all (nor would the relay click). Hazards seemed to work fine with lights on or lights off if I remember correctly. Checked all my grounds and they were fine. It ended up being that one of the tail lights was wired incorrectly and back feeding power. I only noticed it because one side would light up brighter than the other. At first I thought it was maybe just an old bulb on its way out, but I was able to chase it down with a test light.
LX2UN
07-08-2017 04:28 AM
okwaho1650
04-12-2009 07:28 PM
