Motorhomes (Class A,B,C & Super C) F-53/59, E-Series E-350 / E-450 RV Cutaways, Econoline, Transit, Stripped Chassis, Bus Conversions
V10 motorhome codes
Old Jun 19, 2025 | 06:32 PM
2023Cbd's Avatar
2023Cbd
2nd Gear
V10 motorhome codes
Have a 2001 MH that trrough a rod and was replaced with a remanufactured one from AER Manufacturing in Carrollton, TX. It runs find for the first 700 miles but it started giving codes that did not seem correct (etc 6 out of the 10 cylinders not firing but was running good.) Each time it gives a different code. I am thinking it is something in the system that has a bad ground or connection is wrong. Problem is where I live every one just wants to start replacing parts which will be more than I want to pay. Any tips on how to check the computer systems?
Old Jun 20, 2025 | 01:39 PM
rvpuller's Avatar
rvpuller
Veteran: Coast Guard
The first thing I would do is run a ground wire from the engine block to the battery. After that ground the chassis and the body if the engine ground didn't fix it.
Denny
Old Jul 5, 2025 | 12:24 PM
CathedralCub's Avatar
CathedralCub
FTE Community Team
What are the codes that it is storing?
Blown 331
Modular V10 (6.8l)
Aug 26, 2024 07:41 PM
JhamBam
Jun 22, 2021 08:43 AM
jstanley
Dec 28, 2011 05:55 AM
Catman3500
Aug 26, 2008 11:46 PM
leetudor
May 31, 2005 09:37 AM
