3 contribution codes?
Old Jun 19, 2025 | 06:56 AM
Molly4lyfe's Avatar
Molly4lyfe
Good morning, I bought this 03 6.0 with 100k miles that im starting to realize is nightmare. (I cant tell my girlfriend because she didn't want me to get it in the first place)
I have 3 contribution codes
p0269 cyl#3
p0272 cyl#4
p0275 cyl#5
I bought 8 Warren diesel injectors because im an idiot and decided to throw parts at it. Well 3,000$ later and i still have these codes even after resetting them with FORscan. Can someone please guide me in the right direction. I am DREADING low compression. Might actually admit myself to a mental institution if that's the case. All jokes aside,
The 3 contribution codes i had BEFORE the injectors were replaced were for
​​​​​​cyl#1
​​​​cyl#2
​​​​​​cyl#5
One cylinder remained and its #5
I can not run a buzz test, or contribution test with Forscan for whayever reason. Any ideas? Thanks
Old Jun 19, 2025 | 10:25 AM
Molly4lyfe's Avatar
Molly4lyfe
Let me also add. I have not yet tuned the truck for 155 30's. Im going to take a wild guess and say this might be the culprit of my codes?
Old Jun 20, 2025 | 04:01 PM
Baylinerchuck's Avatar
Baylinerchuck
I can’t imagine a tune would cause contribution codes. Since the issue stayed with 5 I’d check the injector harness for damage. Make sure the connectors in the bottom of the FICM are tight and connectors are locked. Really need FORScan or another diagnostic tool to be working to help diagnose. I’d want to buzz test and turn injectors on and off.
Old Jun 20, 2025 | 05:31 PM
Molly4lyfe's Avatar
Molly4lyfe
I have and use Forscan. I do not get a CEL from the contribution codes. Also, buzz tests do not show in forscan on my 03. I've read the pcm doesnt allow them for whatever reason. Not sure how true that is.
Old Jun 20, 2025 | 06:51 PM
Motohead911's Avatar
Motohead911
You really need to get with someone who access to Ford IDS. Then you can run a power balance test, both compensated and uncompensated, and a relative compression test. Also, if yoi can run those test cold.
Old Jun 21, 2025 | 08:07 AM
BLADE35's Avatar
BLADE35
Fuel system aeration test needs to be done
supply side and combustion side
no scanner required this test all testing at upper fuel bowel
you can use a DVM and or noid light to test electrical half
maybe you have bad injections #5 since it only one returning with dtc
Old Jun 21, 2025 | 08:23 AM
BLADE35's Avatar
BLADE35
Originally Posted by Molly4lyfe
I am DREADING low compression. Thanks
Any blow by coming out oil filler spout with cap removed at idle
Engine should draw slight amount air into engine any pressure coming out oil filler neck is problem
Molly4lyfe
Jun 19, 2025 06:04 AM
herschelclinger
Sep 22, 2022 12:34 AM
Loftatsea
Sep 27, 2018 07:24 PM
Luminous
Aug 11, 2017 03:24 PM
jmaskew
Aug 21, 2011 05:47 AM
