Your missing the mounting bracket and pivot arm from the cross member, adjuster and maybe the front cable mount. The rear cables went through a cross member while the cables extended forward to the front. I have all the parts for a F100 but different than the F250. If you have the cables you just need the mounts and connections to tie them together. Should not be hard to fabricate.
