Need help - Window motor replacement
Old Jun 17, 2025 | 07:11 PM
Glenn54's Avatar
Glenn54
I need some help from you guys. I am replacing the window motor on the passenger side. I drilled out the rivets, removed the regulator from the door, and replaced the motor. I am now trying to get the regulator and motor assembly bolted in the door. I can't get the regulator and mount positioned correctly, where the holes in the door line up. Can anyone tell me how to position/align this? This is a 95 F150 regular cab, electric windows.
Old Jun 17, 2025 | 10:46 PM
Glenn54's Avatar
Glenn54
I finally found a Youtube video that does a good job of explaining this job. I am sure I will be able to get this done as soon as a I get a little more time. See attached.
dhuddleson
Nov 14, 2015 06:42 AM
fordtrkman
2004 - 2008 F150
Dec 2, 2009 11:52 AM
Don S.
Aerostar
May 4, 2009 04:37 PM
leesurfer
Sep 26, 2007 07:56 PM
whistling69deuce
Jan 9, 2006 03:38 PM
