Sponsored by: Kumho
Brake pulls left
Old Jun 15, 2025 | 05:41 PM
Wrysdrub's Avatar
Wrysdrub
2nd Gear
Brake pulls left
1997 Ford e150 conversion van, pulls left when braking- I have changed rotors,calipers,pads, bled and still doesn’t fix. Help
Old Jun 15, 2025 | 06:14 PM
tjc transport's Avatar
tjc transport
i ain't rite
simply put, if it pulls left when brakes applied, the right side brake is not working properly.
closely inspect the line from to master cylinder to caliper for collapse if you replaced everything else.
Old Jun 15, 2025 | 09:46 PM
xlt4wd90's Avatar
xlt4wd90
Also look to see if the left suspension if loose in any way.
Old Jun 19, 2025 | 11:24 AM
CathedralCub's Avatar
CathedralCub
FTE Community Team
Could be the left pad dragging or the right pad not doing its job properly.
I don't see on your list where you've thoroughly cleaned the slides then re-lubed them with quality brake lube.
Old Jun 19, 2025 | 01:00 PM
Wrysdrub's Avatar
Wrysdrub
2nd Gear
I am going to check that today. I am thinking you are right. Thank you
Old Jun 26, 2025 | 02:51 PM
xlt4wd90's Avatar
xlt4wd90
Did you perchance change the flex hoses? Internal dissections can prevent fluid from flowing.
Bombergirl01
Apr 20, 2021 05:24 AM
Terry4ford
Feb 20, 2021 02:01 PM
BrownF350
Feb 10, 2017 02:37 PM
FitchBanjos
Mar 3, 2008 11:18 AM
JETSLED
Mar 14, 2007 08:33 PM
