Sponsored by: Kumho
wheel backspacing
Old Jul 3, 2025 | 08:02 PM
Perkial's Avatar
Perkial
Trailering
wheel backspacing
Hi All,
Maybe I'm over simplifying this backspacing issue. I have tubbed my 59 F100. Regular 9 inch rearend, Leaf springs, From my leaf springs to my fender well I have 15 inches of space. From my Leafspring to the face of my drum brake where the wheel is mounted is 9 inches. That makes 6 inches from the drum brake cover to the fender well. Ive bought 12 in wide tires and with the 9 inches of space lets take off two inches for tire clearance . It seems that a wheel with 6 inches of backspace should work fine. Or am I missing something?
Thanks
Old Jul 8, 2025 | 09:57 PM
CathedralCub's Avatar
CathedralCub
FTE Community Team
That math works for me! You'll end up with ~3" between the rim and the leaf springs.
Old Jul 9, 2025 | 12:19 PM
xlt4wd90's Avatar
xlt4wd90
If the tire is really 12" wide, that means you have 3" of clearance, which has to be split between the outside (to the fender lip) and inside (to the leaf spring). Splitting that evenly is 1.5" on each side, which means you want the tire (and therefore, wheel) center line to be in the middle of that 15" space between the leaf spring and fender, or 7.5" from either side.
If the brake mounting face is 9" from the leaf spring, you want a wheel with 1.5" positive offset (mounting face outboard of the wheel center) in order to center the tire/wheel in the available space.
Having just the backspace measurement of a wheel is insufficient; you also need its width.
EG, if you use a 10" wide wheel with a 1.5" positive offset, then its backspace would be 10"/2 + 1.5" + 0.5 (for rim thickness) = 7". The tire would stick out about 1/2" past the rim on each side.
Jacob Bush
Aug 6, 2015 10:47 PM
acf6
Apr 12, 2013 04:45 PM
guidry23
May 30, 2009 12:14 AM
vpracer06
Dec 12, 2007 02:23 PM
bigdonkey
Offroad & 4x4
Apr 8, 2003 06:39 PM
