Engine Removal Question...
Old Jun 15, 2025 | 12:32 AM
Shawn.f.finch's Avatar
Shawn.f.finch
4th Gear
Engine died and I will be replacing. Can I remove it with The exhaust manifolds still attached? It will be easier to remove them outside of the engine bay.😁
Old Jun 16, 2025 | 03:09 PM
G2IC_Wraith's Avatar
G2IC_Wraith
The manifolds are notorious for having broken studs & being a total pain to get them out.
You should be able to pull with them on where you have 2 choices, pull the cab, or remove everything up front & make sure your hoist will lift that high.
Old Jun 16, 2025 | 08:50 PM
tbear853's Avatar
tbear853
I saw a thing on FB from FordTechMaculoco, no failures after just touching welder to manifold bolts to get them red, but not screwing the hex head. The quick super heat and then cooling seamed to break the bond. Might be a video on it?
ericf5674
Mar 19, 2024 10:16 AM
gvolbs78
Garage & Workshop
Oct 22, 2019 05:26 PM
Casey Hughes
2009 - 2014 F150
Aug 9, 2018 07:54 PM
musickerns
1997 - 2003 F150
Nov 6, 2012 11:15 PM
sandrat
Escape & Escape Hybrid
Jan 5, 2007 11:31 PM
