I need an E4OD expert
Old Jun 17, 2025 | 10:34 AM
DittyPitty's Avatar
DittyPitty
Trailering
Originally Posted by Mark Kovalsky
The ground wire is pin 38 on the PCM. The PCM supplies +12v all the time to the solenoid. It turns the solenoid on and off by making or breaking the ground on pin 38.
I probed pin 38 and connected to the chassis ground next to the battery and got OL. PCM was unplugged and trans solenoid was plugged in. Is that the correct procedure?
Old Jun 17, 2025 | 05:49 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Yes, that is the proper procedure. You do not have a short to ground. Now do the same thing, except go to +12V instead of ground. That will check for short to power.
Old Jun 17, 2025 | 07:00 PM
DittyPitty's Avatar
DittyPitty
Trailering
I checked that as well and got OL.
Old Jun 17, 2025 | 07:19 PM
Mark Kovalsky
If you have a code 624, the wiring checks out, then either you have a bad EPC solenoid or a bad PCM.
Old Jun 17, 2025 | 09:21 PM
DittyPitty's Avatar
DittyPitty
Trailering
Is there a procedure to check is the solenoid or PCM is bad?
Caleb Gant
May 16, 2025 03:18 PM
DittyPitty
Apr 15, 2025 09:52 AM
cleon159
Feb 14, 2009 09:19 AM
peters10
Nov 13, 2004 11:41 PM
