E4OD knocking noise
Old Mar 24, 2025 | 05:06 PM
Caleb Gant's Avatar
Caleb Gant
5th Gear
E4OD knocking noise
I haven’t found a post any where with the same problem I’m having so I figured I’d ask myself.
I have a 1994 f150 XL 2wd 4.9L with an E4OD. I’ve had problems with the transmission in the past and did a rebuild about a thousand miles ago. It drove like a champ even under heavy load after the rebuild. I was stopped at a stop sign one morning and when I started accelerating again it started making a knocking noise. The noise is RPM dependent and doesn’t do it in reverse. However even when stationary it makes the noise for a second or two whenever shifting out of reverse into any other gear.
So far I have: replaced the MLPS because it was bad, run the codes and got nothing besides an O2 sensor, checked the torque converter nuts, and pulled the extension housing to make sure the parking pawl spring was still in place. When I pulled the extension housing it drained a lot of the fluid and it still looks brand new with no shaving and no smell.
Any help would be greatly appreciated!
Old Mar 24, 2025 | 06:00 PM
JJF20's Avatar
JJF20
Video of the sounds by chance?
Failing that, have you dropped the pan to check it? Anything laying in there? Did you do any mods when rebuilding?
If nothing in the pan: Im going to say there is a chance something in the rotating assemblies has come loose, broken, snap ring broken, broken sprague, etc. I wouldn’t drive much more on it for fear of further damage or complete failure, including damaging the case. It might be easily repairable right now.
Edit - Have you checked for codes? You mentioned the MLPS, what lead you to that?
Old Mar 24, 2025 | 06:21 PM
Caleb Gant's Avatar
Caleb Gant
5th Gear
I’ve attached an mp3 of the sound (video was too long). It only happens for a quick second when shifting out of reverse but happens continuously when driving. It’s a bit hard to hear but I was shifting from reverse into all the different gears and then back to reverse. It’s that quick clck clck clck clck noise.
I’m keeping it parked until I have it fixed to try and avoid further damage. I was planning on dropping the pan when I have time tomorrow and will update with what I find. The only mod I did was to the pump. I drilled a small hole which helps solve a common problem of fluid not getting to the rear of the transmission.
I agree with you about it probably being in the rotating assembly but I’ll still pull the pan before I pull the transmission just to check. I want to rule out everything I can possible rule out before I pull the transmission.
File Type: mp3
Old Mar 24, 2025 | 06:27 PM
JJF20's Avatar
JJF20
Post up a video on YouTube.
The hole in the pump was probably the drain back at the front seal, it helps fluid drain away and not build pressure against the seal…
Old Mar 24, 2025 | 06:37 PM
Prototypemech's Avatar
Prototypemech
That sounds like your exhaust is hitting your frame or body when your shift between fwd and rev gears.
Old Mar 24, 2025 | 06:48 PM
JJF20's Avatar
JJF20
I didn’t listen. I’m assuming OP ruled out other vibrations and noises. That would be a simple solution.
Old Mar 24, 2025 | 06:52 PM
Caleb Gant's Avatar
Caleb Gant
5th Gear
My exhaust is loose and does smack the frame
Old Mar 24, 2025 | 06:54 PM
Caleb Gant's Avatar
Caleb Gant
5th Gear
That actually sounds about right. It’s been a while since I did it and I’ve slept since then 😂
Old May 16, 2025 | 03:18 PM
Caleb Gant's Avatar
Caleb Gant
5th Gear
Found the issue
After breaking down the transmission I found that the forward planetary gear assembly went bad and was locking up. That’s the only thing I found wrong. Thinking maybe fluid passage got blocked so it was running dry but If any of yall know any other possible causes I’m open to ideas
gov2mod
Mar 15, 2020 03:30 PM
jt holland
Jul 30, 2016 07:14 PM
Skandocious
Jan 23, 2009 02:27 PM
