Oil pickup screen problem
Old Jun 11, 2025 | 01:39 AM
Filsdemorte's Avatar
Filsdemorte
Trailering
Hey all, I've encountered a bit of a hiccup in my engine assembly. The machine shop helped me get the engine components, but I've tried 2 different oil pickup screens and they say that's all they have to offer...
The oil pan is coming from a 1983 f250 so it's a rear sump. The engine is a 1978 460. This engine is going into an 83 f250.
I've tried the melling m84-ds1 and m84-ds2. Neither fit. The oil pan sits a couple inches off from seating. I've seen there are some straight oil pickup screens, should I try for one of those? Both of these pickup screens bolted to the third main cap.
The oil pump I have on it is the melling m84d
Also, I'm swapping out my flywheel since this 460 came from a Lincoln. What's your opinion on the speed master flywheels?
https://www.speedmaster79.com/Ford-429-460-164-Tooth-Internal-Bal.-Billet-Steel-SFI-Flywheel-No-P-Plate-Holes?srsltid=AfmBOoopVl6jCBRGnr_svCb06P1kGrB0Kfho s_HntLUk1cryUbOKsYDu
I really don't want to spend 700 on the l&l flywheel clutch assy.
Old Jun 11, 2025 | 07:54 AM
Max Capacity's Avatar
Max Capacity
Have you checked Summit for the clutch kit. Just get a FW from NAPA or a trusted place.
Sorry I can't help with the oil pick up, other than calling Summit Racing and talk with Tech support, they are helpful.
Old Jun 11, 2025 | 08:16 AM
Max Capacity
https://www.google.com/search?q=ford...hrome&ie=UTF-8
Jegs, would also be a place to call. Both should be able to help you.
Old Jun 11, 2025 | 05:35 PM
Franklin2's Avatar
Franklin2
According to rockauto, those are the correct oil pump and pickup tube for a 1983 f250 with a 460. Do some more head scratching, it's supposed to fit.
Old Jun 11, 2025 | 06:05 PM
Max Capacity
Are there any youtube video showing how to install a _______ on a Ford 460
I see there is even a Ford 460 forum.
https://www.google.com/search?q=how+...t=gws-wiz-serp
Old Jun 11, 2025 | 07:15 PM
Franklin2's Avatar
Franklin2
Are you double dog sure you have the correct oil pan?
Old Jun 11, 2025 | 08:02 PM
Filsdemorte
Trailering
I'm pretty positive, this is a rear sump oil pan with a dipstick. This came off of the 1983 460 that was bolted to the truck. The oil pan I had with my engine originally is a 1978 front sump from a Lincoln. I cannot use that one since the truck it's going into is a 4x4. I triple verified that indeed a 460 was in this truck since I bought it without the engine. The vin and details under the hood show me a 7.5L 460 engine was in there paired up to an NP435 Transmission, and no I wasn't putting it on backwards either lol.. I really have second gussed my self on this, but it really is stumping me. From my research apparently the right p/n is E4TZ-6622-A but I am unable to find that.
If you look at jeffs bronco graveyard they have a sump and a oil pickup that is more straight than the melling pickups. The m84 DS1 and M84 DS2 both bolted to the third maincap on my block. I went and picked up both models because I thought I was going crazy. I was told this is the only one for your engine, but I find conflicting sources stating that the right one should bolt to the 4th main cap.
https://shop.broncograveyard.com/460...uctinfo/30193/
look at this ebay listing for an example. I also did a screen grab of the M84 DS1 and M84 DS2. Those Curves are hitting the rear sump, the DS2 hit the rear sump pan, and the DS1 was hitting the middle of the pan.
The oil pan in those listings look exactly like mine, I measured the depth of the rear sump pan in mine and it is roughly 8.75"
I also snagged a pic of a engine from another FTE Post, if you notice there, on that 1983 block, it has the oil pickup screen on the 4th main cap stud, not the third. Idk, I cannot find the rear sump pickup by itself, I may just have to spend the extra 200 and buy the Bronco graveyard one.
https://www.ford-trucks.com/forums/1...s-correct.html
Old Jun 11, 2025 | 08:04 PM
Filsdemorte
Trailering
I also saw the rock auto for that truck year and it also suggested the Melling pick-up screen. However everywhere I'm reading for the rear sump oil pan, in order for it to fit, it needs to bold onto the 4th main cap. I have bought both of those, and mounted them. They only fit on the third, and hit the bottom of my pan.
I also got skeptical on if I have the right oil pump since nothing is meshing, but the pump I have is the Melling M-84D and that should also be the correct pump.
Old Jun 12, 2025 | 04:59 PM
Franklin2's Avatar
Franklin2
I don't have any more ideas, but I will tell you 2wd or 4x4, they both have to use this rear sump setup. If that helps finding any more parts.
Old Jun 13, 2025 | 07:14 AM
FuzzFace2's Avatar
FuzzFace2
Have you looked into other brand for the part other than Melling?
They cant be the only ones that make the parts.
Dave ----
Old Jun 13, 2025 | 07:51 AM
Max Capacity
Has the OP called Melling ? It's not like they are some no name company. I'm sure your not the first person to do this. They must have some input. Unless you have the wrong parts ?
But I would think any Tech Support at Summit or Jeg's, could also help.
I see in the related threads below, something about van or truck pans...
Nick_S
1978 - 1996 Big Bronco
Feb 3, 2011 02:47 PM
FordTrucksKickGM
Jun 26, 2008 03:01 PM
Tsaven Nava
Feb 25, 2006 11:41 AM
snipa
17
Nov 5, 2004 02:42 PM
