93 Ford F150 Alternator Issues
Old Jun 10, 2025 | 04:18 PM
Fordication's Avatar
Fordication
Hey guys. I replaced my alternator a few weeks ago and it went bad. It showed 14 volts after installed. I replaced it again yesterday and it will not charge. My voltage meter on my dash is not working and has not worked in a while. I have checked the fusible link at the starter relay. Is there any way to check the alternator at the alternator while its on the truck?
Thanks
Ed
Old Jun 11, 2025 | 08:39 AM
dremtofford's Avatar
dremtofford
93 Ford f150 alternator issues
Originally Posted by Fordication
Hey guys. I replaced my alternator a few weeks ago and it went bad. It showed 14 volts after installed. I replaced it again yesterday and it will not charge. My voltage meter on my dash is not working and has not worked in a while. I have checked the fusible link at the starter relay. Is there any way to check the alternator at the alternator while its on the trucks check your grounds 90 of electrical problems are caused by bad grounds.
Ed
Check your grounds.
Old Jun 11, 2025 | 10:51 AM
Fordication
Oh no. It was so much worse than that. I did not realize that my meter did not automatically swap from Ac to Dc and when I saw that I tried it in Dc and bam, it was working all along. ******* cannot read a meter even though I am an electrician. LOL
PersianOrange
40
Mar 23, 2025 11:16 AM
olfordsnstone
Oct 18, 2022 05:45 PM
coolfeet
Electrical Systems/Wiring
Aug 17, 2021 04:30 AM
RangerHaywood
Jul 18, 2011 08:31 PM
sarahnbj
Jun 6, 2011 10:47 PM
