Charging issue?
Old Jul 15, 2011 | 08:33 AM
RangerHaywood's Avatar
RangerHaywood
Charging issue?
Hey guys ive got a 89 F250 7.3idi, with a zf trans. I had my 100amp alternator tested and it was fine, so i replaced the regulator, and ive still got nothing. Where should i go from here?
Old Jul 15, 2011 | 08:47 AM
tecgod13's Avatar
tecgod13
Check the fusible link that runs from the alternator to the starter solenoid. When my alternator let out its magic smoke it took out the fusible link as well.
Old Jul 15, 2011 | 12:23 PM
LSO1123's Avatar
LSO1123
My '93 F250 had a similar problem. It quit charging all of a sudden so I replaced the alternator and voltage regulator and it still wasn't charging. Come to find out the voltometer in the dash cluster wasn't working and for some reason that prevents the alternator from working. I've also been told that if the wire running from the voltometer to the alternator is bad it will prevent the alternator from working.
Old Jul 15, 2011 | 01:01 PM
02X72's Avatar
02X72
Check all your grounds, the regulator needs to be grounded, as does the alternator. Check the battery grounds and block to frame grounds
Old Jul 15, 2011 | 11:07 PM
PLC7.3's Avatar
PLC7.3
Look for the small yellow and white wire from alternator to green wire on the starter relay........I believe it is a fusible link.
Old Jul 16, 2011 | 08:07 AM
RangerHaywood
Okay guys thanks! Im going to try all of your suggestions after work today! I love this site
Old Jul 16, 2011 | 07:27 PM
RangerHaywood
Do you mean the yellow/white wire changes to a green wire or it connects to it at the starter relay? and do you mean the solenoid on the starter or the starter solenoid on the inner fender?
Old Jul 16, 2011 | 07:44 PM
RangerHaywood
Also, what is this wire going to? Battery positive? Ground?
Old Jul 17, 2011 | 11:03 AM
RangerHaywood
Aight so i tested for continuity on the Field, Stator, Alternator, and ignition wires, all with KOEO. All had continuity except for the ignition wire. Pre-continuity test i added a ground wire from the regulator to the battery ground to make sure it was grounded.
The B+ wire was replaced with a heavier gauge wire straight from the alternator to the B+.
So I've come up with the conclusion that it has to be the Fusible link to the ignition switch, the ignition switch, or the gauge itself.
I couldnt find the fusible link to the ignition switch though, do you guys know where it is?
Old Jul 18, 2011 | 08:31 PM
RangerHaywood
Bump...kinda need to drive my truck to an interview on Wednesday...
fallingbroken
Jun 25, 2006 04:32 PM
MRStace84
Paint & Bodywork
Sep 27, 2004 12:01 AM
bassdude
New Member Introductions
Sep 19, 2004 09:18 AM
FEBronco
1978 - 1996 Big Bronco
Jun 28, 2004 05:44 PM
alfcapone
Sep 5, 2002 05:04 PM
