Engine won't stop
Old Jun 6, 2025 | 01:17 PM
Mastiff37's Avatar
Mastiff37
Engine won't stop
Hey guys. I'm at work and my son tells me that the 1993 F250 7.5L just keeps running with the key out. He pulled the negative cable from the battery and it kept going, which maybe isn't surprising? Maybe just running on alternator. Going after fuel pump fuse next.
Is this just a bad ignition switch probably? We did just replace the alternator, but there wasn't much to do wrong there.
Old Jun 6, 2025 | 01:38 PM
Prototypemech's Avatar
Prototypemech
This is usually caused by owners doing electrical work and accidently splicing an ignition wire to a b+ wire. there are multiple ways of stopping the engine. Removing the coils high tension wire (the thick one) is the easiest
Old Jun 6, 2025 | 01:44 PM
Mastiff37's Avatar
Mastiff37
It's been fine for a few years. Alternator is the only thing electrical related. Stopped it with the fuse. Maybe it'll be obvious when I get home.
Old Jun 6, 2025 | 02:39 PM
Duke5A's Avatar
Duke5A
Pig metal linkage from the starter switch on the underside of the column to the key tumbler probably broke. It'll push forward to start the truck, but pull back on it and it'll do nothing. You can remove the starter switch from the column via two torx fasteners and actuate it by hand until you get the linkage in the column fixed.
Old Jun 6, 2025 | 06:16 PM
Truckbuck's Avatar
Truckbuck
The way I align the ignition switch is I turn the key all the way to back, or the accessories position, and then push the ignition switch all the way forward towards the engine. I had some weird electrical problems, traced it down to the switch being bad and being misaligned.
Old Jun 6, 2025 | 06:49 PM
Mastiff37's Avatar
Mastiff37
The key switch is totally floppy. Obviously not engaging the actual ignition switch. Is there a part I can replace, or is the column shot? I'm staring at this stuff, it's not clear exactly how the linkage goes when it's working.
I'm guessing this is part of the puzzle:
Amazon Amazon
Old Jun 6, 2025 | 07:41 PM
Mastiff37's Avatar
Mastiff37
Okay, more data: I watched some video so I knew where to look, and the actuator rod does move with the key. I pulled off the ignition switch, and the plastic block in there that engages the switch does not move... so, could be the block or maybe the end of the actuator rod? Looks like the rods are easy to find, but the blocks not so much.
Old Jun 7, 2025 | 04:02 AM
C6Scott's Avatar
C6Scott
i do all the Ford steering column repairs that come in to our shop and I’ve never seen the lower part of the actuator broken. It’s always the top piece. If you do end up needing the bottom/ lower piece that engages the ignition switch and can’t find it I could send you just for shipping or you could pick it up free in Indpls. Either way I’d make sure and clean both parts up and the slot/hole they travel in and re-grease them if it were my truck.
Old Jun 7, 2025 | 06:01 AM
manicmechanic007's Avatar
manicmechanic007
The pin falls out of that plastic ignition actuator
You'll just have to remove the tilt pins and disassemble the tilt mechanism to replace the actuator
That is a decent, hard, big job for a first timer
It can be done
We all had to learn sometime
Trick is find the right screw threads and screw a screw / bolt into the tilt pin, then pull the pin out with the bolt using dykes
Then the spring will fight you but if you hold your mouth just right...you'll get it apart and back together
Keep in mind that the gear teeth need to mesh properly, be "clocked" correctly to work
So, test it a few times before going all the way back together
Old Jun 7, 2025 | 08:43 AM
Mastiff37's Avatar
Mastiff37
Well, I don't have the tilt steering column, so that might make it a little easier at least.
Do you guys think I ought to remove the whole column and work on the bench, or can I manage this just dropping it down still installed? I've had it somewhat far apart before to replace the shift tube.
Also, am I going to need to separate the column? I'm not totally clear what that's all about but it looks like a pain fighting some springs or something, unless that's related to the tilt steering somehow.
Makes sense about removing the block and cleaning that up, but it also looks like a painful part of the job. People claimed they could replace the actuator rod without it coming out?
Thanks for the help!
This is the best video I found so far, BTW:
Good writeup on removing the whole column: https://www.steeringcolumnservices.c...FordColumn.pdf
Old Jun 7, 2025 | 09:35 AM
C6Scott's Avatar
C6Scott
Thankfully on yours the tilt pins just unscrew with a t-30. It is a pain to remove the block because you have to remove the pin under the shift tube that holds the lever that locks the gear in park when the key is off. If it feels like it doesn’t want to move though it needs greased. That’s gonna be a judgment call. Yes you need to separate the column to do it right. With it being non tilt it’s a lot easier because you don’t have to fight the spring to put it back together. I take them out and do it on the bench usually but you don’t have to. Some people prefer leaving them in place. What manic said about it being clocked right or in time is very important. You have to get that right. The first tooth on the actuator is big and it fits into the big slot on the gear. If the pin fell out which is pretty common like manic said you could put it back in without disturbing the timing of that gear. I usually replace them when the pin comes out personally.
Old Jun 7, 2025 | 09:51 AM
Mastiff37's Avatar
Mastiff37
How do you like to separate the column? I saw one video where he used a C-clamp to press as a makeshift compression tool, and another where he used two screwdrivers and pried it up. The C-clamp guy was doing a Ranger and it only had one latch thing instead of two.
Old Jun 7, 2025 | 09:54 AM
C6Scott's Avatar
C6Scott
I usually take it all the way apart so it’s different but you can do it either of those ways. Yours only has one latch being non tilt. I can see it in the picture you sent.
Old Jun 7, 2025 | 12:16 PM
Mastiff37's Avatar
Mastiff37
Got the thing out and on the bench. Hardest part was getting the shifter cable stuff off. I notice the turning of the steering shaft itself feels a bit gritty. Is that normal, or do I need to get some grease in there someplace?
Old Jun 7, 2025 | 12:25 PM
C6Scott's Avatar
C6Scott
it’s normal on trucks this old but it’s not supposed to be that way. There are three bearings if you have a shaft with the u-joint and two if you have a solid shaft. Non tilts do come with both. The solid shaft usually is in the more heavy duty trucks but not always. If there is a spring on the opposite end of the shaft from the steering wheel you have 3 bearings. If there is a c clip you have 2. You can try and grease them and it would probably help some. Replacement would be best tbh but it’s a good amount of work. Could also be dirt between the top bearing and the piece that contacts it. Maybe could blow that off with air and help a little.
