Battery Maintainer/ Charger
I also worry about their charge voltages a bit. I'm still analyzing the charger when I can. I have not seen proper charge voltages yet but it seems to be doing it's job.
I sometimes even remember to switch to AGM mode when connecting to the little batteries in ATV and mower. Hope that’s not too critical 😳
I have tried the repair mode but didn’t have much luck with it on failing batteries. Some reviews said that it works but
. I can’t fault the charger though as the batteries I’ve tried it on weren’t in good shape.
that's not good, I placed an order for the 15A, actually 2. The 5 or 7A doesn't seem much smaller. I will figure something out. Will have to be creative i guess, we'll see. I chose the 15A because they had the open box versions available and wasn't much more and I figured I could adjust the output if I ever needed to.
If I figure out anything good, I'll be sure to share it.
Charger isn't warm nor the battery, so i'm not too worried...just seems odd.
The Victrons should be here in a couple days. I have another identical group 31 X2 odyssey extreme I need to charge up and check. So I will see how the Victron does in comparison.
I just noticed the Victron's don't come with an inline fuse but they offer an accessory plug that does have an inline fuse...that's about silly. I was going to order come of the accessory plugs too. Oh well, I have some in line fuse holders I can splice in or can come up with a different solution.
Now that I'm looking...the supplied battery clamps don't either but they sell sets that do...WTF!
Anyway, I'm just trying to provide some useful info to any newcomers that come across this. Most probably won't even care.
