1988 power window problems, left me stuck.
Old May 28, 2025 | 03:36 PM
karljay's Avatar
karljay
I replaced the defective passenger window, and it was a PITA because it's riveted in place and the access is small. That was years ago. Now I go to the store and my driver's side window was fully down and it stopped working.
I can't secure the truck.
I get home and tear it down and look for a new motor/regulator setup and all the sudden, after grinding out the rivets, the motor works again. I cleaned, lubed and put it back in.
Here's the issue, I _THINK_ the problem was in the stopper. The peg that prevents it from going to far, seems to have wedged the regulator so that the motor couldn't move it.
I don't want to get stuck with this PITA problem again.
Has anyone else had this problem where the stopper peg caused the window to lock in place?
Is this one of those "known" issues that wasn't known to me?
BTW, A quick tip: I used an Irwin Quick Grip clamp to hold the glass in place. One place was about 1/2 up and that as just to claim the glass, the real trick was to use one end of the clamp to go UNDER the glass between the door and the glass and wedge it against the door top on the inside, it's adjustable too. Works great, hope it helps.
rogersdan
Jul 22, 2020 05:03 PM
GuitarJesus
Feb 24, 2014 08:18 AM
Kelly Aitken
May 6, 2013 02:37 PM
woody_f250
Sep 1, 2005 10:04 PM
odinmurphy
Jul 3, 2001 05:41 PM
