Transmission cooler options
Thanks
1162 posts and no truck info.
But if it is indeed a 99-03.
https://www.riffraffdiesel.com/mishi...transmission+c
Or go to the Ford counter and get OEM 6.0 cooler and source a couple of reducers and line.
Get an OEM 6.0 cooler wether it be 26 row or 31.
or get a dieselsite 40 row cooler.
No, you do not want to bypass the radiator cooler
I have towed over 8000 lbs, over 6,000 miles, over Loveland pass once, and through Albuquerque twice, and it did not overheat.
This trailer went over Loveland Pass to my home, and a few months later, to my son's home in Dawsonville, GA, and the TFT never exceeded the EOT. The Dump trailer was loaded with a load of pig iron from the farm up in Utah, it was Heavy....
Price, UT to I-70 thru Kansas to Tulsa, OK to my home, then a few months later to Dawsonville, GA
and this is the highest TFT that I have ever seen.
I never tow over 70 mph, that is for brave hearts with a big Wallet.
Ford eliminated the in tank cooler when the Superduty launched in the 1999 model year. Transmission cooling was a DISASTER. Many, many transmissions were burned up and replaced under warranty. It was so bad that Ford reintroduced the transmission cooler in the radiator in February, 2000.
You guys that tow on the freeway, and especially ones that replaced the not so good stock cooler with a 6.0L cooler, usually won't see a problem. Those that tow in stop and go and do a lot of backing really need the radiator cooler.
AGREE!
The truck with flatbed scales almost 10K. Trailer, Tractor and Cutter are 20K. 6.0 cooler keep the transmission 173 degrees in 90 degree weather this weekend.
The OP reported experiencing elevated transmission temperatures (252°F) in the mountains, and ONLY in the mountains. Apart from the mountains, the OP otherwise reported that "my truck does fine with the stock size cooler 99 percent of the time."
Experience in states not known for significant mountains may not mirror the experience of the OP's driving environment.
Popular cottage industry purveyors in Florida, Georgia, Texas, and other southern states come up with various deletions that seem to work just fine in those states. Yet Wyoming, Montana, Colorado, Canada, and California (apologies for even mentioning California in the company of those other fine states... ahem... there's a third joke hidden in there somewhere) present more challenging operational environments.
That the 6.0L oil to air cooler is as effective as it is, can be attributed to the team at Ford that Mark Kovalsky was a part of for the 5R110W. And despite being on the team that validated a fantastically effective oil to air cooler, even Mark emphasizes the importance of the oil to water transmission cooler in the radiator. (Mark did not work on the 4R100, nor with the 4R100 cooling "genius" responsible for making the tenuous case to remove the OTW cooler in 1998, only to restore it again in 2000, due to rampant transmission failures without it.)
Keeping the Oil to Water transmission cooler in the radiator in tact is STRONGLY advised. I changed radiators in order to have that OTW cooler. I only run a V10 oil to air cooler, as the smaller V10 cooler isn't as tall as the 6.0L coolers, and as such, does not block the front face of, nor reject it's heat into, the charge air cooler. The oil to water cooler in the radiator enables me to run the smaller V10 oil to air cooler, which is still larger than the original 7.3L oil to air transmission cooler.
The 6.0 cooler is remarkably well designed and does what its supposed to no matter how it is plumbed in the truck. By no means am I advocating deleting the oil to water transmission cooler, but I certainly wouldn't be going out of my way to add it if I had a a truck that came from the factory with out it.
I have never seen the TFT get even with the EOT.
3 trips to Utah and back, and one trip to Georgia and back, make that twice, once empty and once towing the big Dump Trailer loaded with pig iron.
