Upper ball joint replacement
Old May 21, 2025 | 06:12 PM
unibody62's Avatar
unibody62
I found out my upper ball joints are shot, so I ordered replacements from RockAuto. Afterwards, I did some checking around and wondered if the whole control arm needs replaced. The alignment shop just mentioned ball joints so I’m hoping they can be pressed out. One video said the whole upper arm would have to be replaced, but they sell plenty on RockAuto without the whole arm. I don’t really want to get started and then find out I need different parts.
Old May 21, 2025 | 06:34 PM
Papa Tiger's Avatar
Papa Tiger
You may need a butane torch with a hose to heat the area where the Ball joint needs to disconnect after removing the nut.
I recommend the hose style as it is a safer method. It will also loosen a red Loctite fastener. Sometimes for no reason
They just get red Loctite, because someone dis something with the suspension in the past.
The picture is the reason for the disassembly. You then need to have its alignment checked. Replace the shocks with gas
is my recommendation at this time also. A 2" lift shock is a great choice; you will like it. Levels the truck out. Changing Tie Rod
Ends are a great choice now too.
Since you have it apart I would also recommend replacement of the front wheel bearings. Not knowing your mileage they usually fail around 100,000 miles and make a noise.
Lots easier to change them with the spindle off. 18 wheelers are just turning our roads around here into chuck holes and ripples. Very hard on the bearings.
Old May 21, 2025 | 07:24 PM
unibody62's Avatar
unibody62
I put Bilstein shocks on at 28K right after I bought the truck. They should still be good with only around 55k miles since then. I needed a little lift for snowplowing. So the video shows replacing arms. I’m sure that might be a little easier, but the parts are more expensive.
Old May 21, 2025 | 11:12 PM
Papa Tiger's Avatar
Papa Tiger
Check out Amazon Prime. $100-$150 the complete thing. List your truck and it will tell you if the parts will fit yours.
Old May 22, 2025 | 07:07 AM
unibody62's Avatar
unibody62
I try to avoid Amazon for car parts, you can’t always trust that they aren’t fake brand names. I found some on RockAuto for about $50 each. Mevotech is the brand, which I know nothing about. I guess you never know about Moog parts whether they are made in China. I think you have to be familiar with the part numbering. The Alignment Shop told me the strut needs to come off to get the bolts out. We’ll see, but I’m hoping not, but I don’t think even that should be hard.
sam hain
1997 - 2003 F150
May 23, 2025 11:39 PM
joeltwise
1997 - 2003 F150
Jun 21, 2009 09:37 PM
jadams1978
1997 - 2003 F150
Nov 10, 2006 12:41 PM
mmorto
1983 - 2012 Ranger & B-Series
Aug 27, 2006 11:09 PM
FTE Ken
Nov 23, 2002 06:46 PM
