Upper Ball Joint Replacement
Old Oct 29, 2000 | 09:19 PM
FTE Ken's Avatar
FTE Ken
Old Nov 19, 2002 | 08:06 AM
RangerBob98's Avatar
RangerBob98
I have a 98 Ranger that needs a right side upper ball joint. I went to Autozone and the part they ordered in looks nothing like my existing control arm. The part, which cost $42.00, is a partial control arm with a pressed in ball joint, the arm has slotted holes to either side and a 90 degree return at one end.
After returning it, and scratching our heads a bunch, we ordered a complete assembly, which we think is going to be a replacement control arm which accepts the partial control arm with ball joint.
I ordered the whole new assembly and they took back the partial control arm and ball joint. I'm not very confident that this is 100% correct, and although my local Autozone guys are great, they don't have me fully convinced.
Has anyone run into this? I know it's early for ball joints on a 98, but I just rolled 127K.
Old Nov 19, 2002 | 09:10 AM
greenpus's Avatar
greenpus
I just replace the balljoints. Moog makes the balljoints for the 98+ 2wd rangers. They can be bought at http://www.oreillyauto.com/index.html
Old Nov 19, 2002 | 12:22 PM
MnDot51's Avatar
MnDot51
Hi, I have a question about ball joints. I have been told by a dealership and an independant shop that my lower ball joints are loose and need replacement. The independant guy suggested I do the uppers as long as I'm at it.
My Ranger is a '96 with only 73k! Is it a bit early for the joints to go??
Thanks for the info!
Old Nov 19, 2002 | 05:50 PM
RangerBob98
Thanks for the link to Oreilly's but I still have a problem.... they want $75 plus shipping for the ball joint and I still have to remove the old one and press in the new one. How involved is this process and is it worth the trouble to save $40? There's also the concerns of taking apart the upper control arm bushing to get the ball joint in a press and then reinstalling them.
Old Nov 20, 2002 | 07:45 AM
greenpus's Avatar
greenpus
[updated:LAST EDITED ON 20-Nov-02 AT 08:51 AM (EST)]You get what you pay for. I would imagine the control arm you are getting from autozone is some cheap crap made in china. I would rather spend the 75.00 then buy parts from autozone.
I have a small press and I did not remove the upper and lower arms to press in the balljoints. I did put the balljoints in the freezer before installing. This makes them easier to install. Cold metal is slightly smaller then hot metal so they fit in the arms better for installation.
If you want to remove the upper and lower arms it really is not that hard but is very time consuming if you have never done it before. Just make sure you have new cotter pins and a torque wrench. A pickle fork will be very helpful too....... You might as well go all the way and repack your front wheel bearings and replace the brake pads and have the rotors turned if needed because you will be taking those items off as well.
Old Nov 20, 2002 | 06:41 PM
RangerBob98
I don't have a press handy so this really isn't an option.
Old Nov 22, 2002 | 10:11 AM
ranger pat's Avatar
ranger pat
Veteran: Navy
The dealer right hand side upper control arms you describe that have adjustable slots are only used on 4x4 suspensions. I take it yours is a 4x2. Dealer 4x2 upper control arms are available. Re-check your dealer for the correct part.
Old Nov 23, 2002 | 06:46 PM
RangerBob98
Well, I completed the job finally. It took about an hour from start to finish. I suggest that anyone who runs into this simply orders the part from Ford. I spent time and money waiting for parts to come in from parts stores only to discover they were incorrect. The odd thing was, they were ordereing the correct part based on the catalogs they had, and this was at two different dealers with two different suppliers (moog was one of them).
It cost a lot more but I got my truck back on the road and I don't have to drive my wife's Hyundai anymore!
