Traction bars
Old May 20, 2025 | 07:54 PM
c00nhunterjoe's Avatar
c00nhunterjoe
Traction bars
Looking for axle wrap solutions. Any preferences on one brand or another for traction bars? Debated making a set but extra time is not a luxury I have at the moment.
Old May 20, 2025 | 07:59 PM
INFRNL's Avatar
INFRNL
I run PMF bars that attach to the axle with the u-bolts. I had to convert to flip the u-bolts and upgraded to 3/4"...I have a Dana 80. They do the job for what i need. they helps smooth out shifts as well.
One Up Offroad used to make a killer kit but they sold out to S&B. Not sure when they were last available but S&B doesn't seem to support us anymore besides intake and cab mounts
Old May 20, 2025 | 08:08 PM
c00nhunterjoe
I don’t want to flip the u bolts. I would weld bungs or another style
Old May 20, 2025 | 08:22 PM
INFRNL's Avatar
INFRNL
they do offer weld on. I'm not sure what all Trevor offers now. I chose my option because i didn't feel like doing any welding.
I'm also not sure whom all makes a good kit but I'm sure there are options
Old May 20, 2025 | 08:23 PM
Tpayne621's Avatar
Tpayne621
I used the DIY kit from far from stock. Comes with everything needed and you just weld it up.
Old May 20, 2025 | 08:33 PM
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
I went with One Up Off-road 8+ years ago and have zero regrets. PMF was a close second and would likely be my choice now if OUO sold.
Old May 20, 2025 | 08:55 PM
INFRNL's Avatar
INFRNL
I wish S&B would continue the OUO kit, I was going to buy one for my 76 project truck
Old May 21, 2025 | 09:03 AM
FordTruckNoob's Avatar
FordTruckNoob
I like the idea that @brokestroke came up with that goes to the pumpkin of the axle.
Old May 21, 2025 | 09:48 AM
BWST's Avatar
BWST
Got Data?
I need a set as well – preferably bolt-on. I don’t trust my welding skills for the beefy stuff. Only welded thin sheet metal for bodywork so far.
Old May 21, 2025 | 03:32 PM
callforfire's Avatar
callforfire
I also run the bolt-on PMF traction bars. It was the first item I bought from them, and now all of my suspension is PMF.
Old May 21, 2025 | 04:04 PM
BWST's Avatar
BWST
Got Data?
@Wes444 do you still like these Pro Comp bars on your rig?
Pro Comp Traction bar install - Ford Truck Enthusiasts Forums
Old May 22, 2025 | 04:06 AM
Wes444's Avatar
Wes444
Yes I do
Old May 23, 2025 | 08:19 AM
udsuth78's Avatar
udsuth78
I haven't run traction bars so no advice or recommendations but what finally worked for my truck was some simple spring clamps I threw together with some 1/4 x 1 1/2 angle iron and 5/8 grade 8 bolts. There was a little trial and error finding where to place them on the spring. The Googleverse has a few different schools of thought on theory but I ended up with two clamps /spring, one forward and the other rearwards. Between the x'clamps and making sure the pinion angle is set correctly finally cured my axle wrap issues.
Old May 23, 2025 | 01:01 PM
Arizf250's Avatar
Arizf250
4th Gear
Do you have the gusseted or the tubular design? I'm looking for something for my 2024 F250. I have terrible axle wrap when towing my travel trailer through the sand dunes.
Old May 23, 2025 | 09:36 PM
INFRNL's Avatar
INFRNL
for you, look at the S&B bars, they are real nice like
