Icon spring rate vs Deaver
Old May 14, 2025 | 12:19 PM
73excursion's Avatar
73excursion
2nd Gear
I have an 02 excursion with essentially a Carli kit other than I didn't replace the front leaf springs as the truck came with an almost new set of Icon 4 inch lift springs. My question for you guys is whether or not anyone knows what Icons spring rate is and if its worth buying the set of front leaf springs that the Carli kit comes with so everything matches up or if I should just leave it as is?
Old May 14, 2025 | 04:50 PM
73excursion
2nd Gear
Does anyone happen to at least know what the spring rate is for Icons 4 inch lift front leaf springs? I called Icon and they had no idea.
Old May 14, 2025 | 06:22 PM
INFRNL's Avatar
INFRNL
Most places probably wouldn't even share that information...the question is, do you like the way it feels? If you are okay with the ride, then I wouldn't even mess with it.
Okay, I just looked up the Icon and looking at the front springs; they will most likely be very similar to deaver springs if they aren't already.
97vanswap
Mar 9, 2022 11:58 AM
WildPferd
Bronco II
Nov 22, 2008 09:13 PM
zstyle01
May 22, 2007 09:44 PM
cjhofer
Sep 7, 2006 03:33 PM
rhetor
21
Jun 30, 2004 07:29 PM
