Bronco II Ford Bronco II
Leaf spring helpers
Old Nov 13, 2008 | 08:20 PM
WildPferd's Avatar
WildPferd
Leaf spring helpers
as opposed to using an ad a leaf kit or replacing the leaf springs as a whole.... I need to recover about 2 inches in the back due to saggy leaf springs....any thoughts?
Old Nov 15, 2008 | 01:33 PM
Help I M Stuck's Avatar
Help I M Stuck
Rear leaf springs out of an explorer are supposed to give it lift..
Old Nov 16, 2008 | 12:02 AM
97Centurion's Avatar
97Centurion
Rub my Belly
Might give it to much. Might not. Usually they give it an 1 1/2 or 2 above factory stock height. At least mine did. Little stiffer ride but some people like that.
The easiest would be adding an overload spring. They aren't to hard to install. It would probably stiffen the ride some but it is probably already "soft" due to the saggy springs.
You could also install a 2 inch lift blocks to get it back up to proper height but you'd need to change out the u-bolts for longer ones.
Old Nov 17, 2008 | 03:43 AM
WildPferd's Avatar
WildPferd
put the leaf spring helpers on....seem to work....gave me about an inch and a half and now the truck is ALMOST level
either way...as long as that doesnt stress out the orig springs too much it should work
Old Nov 20, 2008 | 09:15 PM
eveready77's Avatar
eveready77
I swapped in explorer springs all the way around my '89 BII. Definitely stiffens the ride up, But it's not as stiff as helper springs that I have dealt with before. Also I bought my springs for under $100 for all four off an explorer with less than 30k miles. Not sure what helper springs will run you. Just my $.02
Old Nov 22, 2008 | 09:13 PM
WildPferd's Avatar
WildPferd
Yeah, they were 30 bucks
Supercab
Jul 24, 2012 02:57 PM
ozblitz
Jan 2, 2010 06:29 PM
truckmek
Dec 16, 2007 10:06 PM
mnm99
1978 - 1996 Big Bronco
May 4, 2003 12:26 AM
iknowitall
All Things Towing
May 18, 2001 10:09 AM
