Sponsored by: Real Truck
P0346
Old May 8, 2025 | 01:57 PM
K5BEAST's Avatar
K5BEAST
P0346
2009 f250 superduty 5.4 3v. Engine is new reman with 1000mi on it. I'm getting an intermittent P0346 code. No other codes. I can clear it and it will remain gone for days. Truck runs fine. Idle s, drives as our should, etc. I replaced the cam sensor in bank 2. No change.
should I be worried? And what may be causing this? I believe the wiring is all good as it is clean and factory bundled work no damage spots, etc.
Old May 9, 2025 | 09:50 AM
shaun.be's Avatar
shaun.be
Just because wiring looks good doesn't mean it actually is, especially since the harness has been moved for the engine replacement it could have a broken wire inside the insulation.
Old May 9, 2025 | 10:07 AM
Eman85's Avatar
Eman85
A quality scan tool should show data and what it saw upon the failure to set the code, start there. New sensor doesn't always mean good sensor and if it's good it can only sense what it sees.
woody367
Jan 13, 2025 01:38 PM
sohcmike
2004 - 2008 F150
Apr 15, 2021 11:44 AM
AlanM
Modular V8 (4.6L, 5.4L)
22
Oct 30, 2014 08:24 PM
Hunter7.3
May 4, 2013 10:08 PM
