5.4L Cam Position Sensor Code
Old Apr 12, 2021 | 10:10 AM
sohcmike's Avatar
sohcmike
4wd Low
Hi Guys
Have a 2006 King Ranch F150 with a 5.4L engine. The truck starts and runs smooth from start up, then starts missing like crazy and will barely run after driven a few miles. We had the codes checked and it said to replace the cam position sensors. We replaced them and it does the same thing after driven a while. When it acts up, you can disconnect the battery and it starts and runs fine until it acts up again, missing like crazy and barely running. Is there something else possibly wrong or is the timing chain set just plain worn of and needs replaced? Thanks for your help.
Mike
Old Apr 12, 2021 | 05:26 PM
Johnny Paycheck's Avatar
Johnny Paycheck
What were the codes? That said, there are no codes that say “replace that sensor”. With DTCs, it’s more likely telling you, “Hey, I’ve got trouble, check this out!”
Are you headed for a timing chain job? Maybe. Many 3V 4.6/5.4 engines have that fate.
Old Apr 12, 2021 | 05:39 PM
muhford's Avatar
muhford
Time for a new engine.
Old Apr 13, 2021 | 10:15 AM
sohcmike's Avatar
sohcmike
4wd Low
Its throwing a P0340 code
Old Apr 13, 2021 | 05:06 PM
pdqford's Avatar
pdqford
The description for that DTC is “Camshaft Position CIRCUIT Malfunction”.
Old Apr 13, 2021 | 09:26 PM
Lime1GT's Avatar
Lime1GT
It's possible you may have a bad diode or open phase connection in your alternator. There is a TSB 06-19-12 for a P0340/P0344/P0345/P0349.
Old Apr 14, 2021 | 06:02 AM
sohcmike's Avatar
sohcmike
4wd Low
The parts store recommended cam position sensors for the fix. We have replaced them twice and the problem persists.
Old Apr 14, 2021 | 08:07 AM
RLXXI's Avatar
RLXXI
The sensors are "sensing" a problem thus doing their job. People that work in parts houses know as much about diagnosing as the kids flipping burgers at McDs.
Old Apr 14, 2021 | 05:42 PM
muhford's Avatar
muhford
I sold parts for 2 years and the worst customers were the ones who wanted me to diagnose and sell them exactly the right part. Who expects a cashier to sell you the correct part without even looking at your vehicle?
Even worse corporate advertised us like we were master mechanics and not just cashiers. A cashier making $8 an hour isn't going to diagnose your car.
Old Apr 15, 2021 | 11:04 AM
Lime1GT's Avatar
Lime1GT
While I don't expect parts salespeople to be able to diagnose vehicles they do come in handy in that they see the most common parts being sold in volume for certain issues every day. Somewhat good advice for mechanical parts such as suspension, brakes, etc. However for sensors like O2's, crank and cam, volume sale doesn't work for me. This is because some diy people don't know how to interpret their scan tool results and the first thing they change needlessly are sensors.
Old Apr 15, 2021 | 11:44 AM
70f100longbed's Avatar
70f100longbed
Hi Guys
Mike
The description of the code is misleading. Your symptoms point to low oil pressure when warm and worn/broken timing chain guides. Most likely it will need the engine replaced. These are not cost effective to try to patch up. There are too many problem areas that need work.
bellinoracing
2004 - 2008 F150
33
Sep 11, 2019 08:56 AM
lj8215
Jan 14, 2017 09:48 AM
Jonathan Day
2004 - 2008 F150
Oct 3, 2016 04:06 PM
Jay David
2004 - 2008 F150
Mar 16, 2016 05:44 PM
wycowboy
Jan 4, 2005 09:42 PM
