Sponsored by: Real Truck
Fixing engine code but 1 still remains
Old Jan 12, 2025 | 06:05 PM
woody367's Avatar
woody367
So I guess I did not fix my codes. I had P0133, P2195 and P2197. Engine was running rough at idle and even stalled but fine at driving speed. It is a 04 F250 5.4l 2V. I replaced both sides sensor 1 with new Motorcraft O2 sensors. Truck is running better but am still getting code P2197. What could it be and what to do next? Thanks
Old Jan 13, 2025 | 08:33 AM
shot93's Avatar
shot93
Cam phaser solenoid will cause it to run rough. I am not sure what codes it would cause.
Old Jan 13, 2025 | 09:36 AM
woody367's Avatar
woody367
The 04 f250 5.4 is a 2v no cam phasers.
Old Jan 13, 2025 | 01:38 PM
Mike1's Avatar
Mike1
Leaking exhaust, Leaking vacuum, leaking intake, faulty new sensor, bad wiring, Swap sensors see if the code moves to the other side, check for cracked or missing vacuum lines check the intake gasket for leaks, check the wiring real good for breaking , fraying, Check continuity on O2 wires back to ECM, Possibly the ECM may be bad or going bad, pull main plug on ECM and check for corrosion on pins and any pins that may be bent or pushed back.
1990f250engine
Nov 10, 2024 05:32 AM
NotEnoughTrucks2014
Apr 29, 2018 08:28 AM
woody367
Jan 19, 2011 02:13 PM
geta4x4
Feb 28, 2009 06:56 AM
93truck
Jun 15, 2006 09:53 PM
