6.0 high egts
Old May 7, 2025 | 12:36 PM
kbeefy's Avatar
kbeefy
Originally Posted by TRMK
Weird thing is to me is if it stays in 5th with the converter Locked up it stays cool, if it downshifts it heats up. That’s backwards of how I always thought it should be.
I have an 05 I recently started towing with. I have an SCT tuner and the canned tunes.
I haven't let it get over 1300*, and only for an instant when I wasn't paring attention, but I have noticed what you mention above.
I can be pulling a hill (towing 11k) and when it gets to 1100-1150 I want it to downshift. Well, theres no way to manually disengage OD on my truck so I either back off or stab the throttle a bit to get it to downshift. This gets me about a 900 rpm gain and increased EGT's. I have to slow down a bit (to 55-60) and let the EGTs settle down.
I believe it is both down shifting and unlocking the converter at the same time, netting the 900 rpm gain. Typically from 1900 rpm to 2800 rpm.
I know that while accelerating through the gears I will be reading 1900, 2200, and 2800 respectively at that speed depending upon what gear or converter status is.
I haven't came up with a fix, but I was planning on addressing the shifts with some custom tunes.
I did try stock, tow, and aggressive shift options on the sct, no change.
Old May 8, 2025 | 09:27 PM
Baylinerchuck's Avatar
Baylinerchuck
it runs hotter in the “stock” tune than the tow tune. It’s got some kind of flash tune on it. Where is your EGT probe?
Mine is on the drivers side manifold near the outlet.
Old May 12, 2025 | 09:51 AM
MisterCMK's Avatar
MisterCMK
That sounds about right. Put a KC stage 1 on it and your temps will drop to below 1400 on a hard pull
doug7deuce
Aug 25, 2015 06:36 PM
Banshee Ben
Jun 30, 2010 01:06 AM
hank89
May 24, 2010 07:27 PM
Firefighter 1406
Jun 23, 2009 02:54 AM
endobear
67
Mar 26, 2009 05:29 PM
