1994 F150 problems
Old May 2, 2025 | 08:06 PM
1994F150351w's Avatar
1994F150351w
4wd Low
1994 F150 problems
Got this 1994 f150 351w 2wd a few weeks ago and it is having some issues. It gets garbage fuel economy, has a check engine light, and blows black smoke out of the exhaust. I scanned the computer and got these codes.
117
638
126
122
112
327
513
553
552
565
556
all these codes have the same general meaning of “below min. Voltage” or “circuit failure” or “voltage failure”. What does this mean? What do I need to replace? TIA, any help is appreciated.
Old May 2, 2025 | 08:26 PM
Soup bean's Avatar
Soup bean
Sounds like a computer (PCM) problem. Leaking capacitors and burnt traces are a common problem.
The PCM is removed by pulling it into the engine bay, after loosening the bracket behind the driver's side kick panel, and unplugging the main harness connector, by loosening the 10 mm ? bolt, that secures the connector to the PCM. You might need to remove the fender liner.
Also, check out posts 6 and 7 at this thread https://www.ford-trucks.com/forums/1...nd-points.html
It would be a good time to clean, tighten and replace ground connections if necessary. The main ground cable from the battery negative terminal to the engine block and frame, can corrode internally.
This style of battery terminal is known to cause issues (ignore the arrow)
Old May 2, 2025 | 08:44 PM
Prototypemech's Avatar
Prototypemech
Remove your ECU and open up the cover to look inside. You'll probably find some capacitors that have leaked and damaged your circuit board.
connman12
2021+ F150
Jun 9, 2025 01:15 PM
1969Highboy
Mar 24, 2009 06:18 PM
92302FREAK
Feb 8, 2008 09:35 AM
ANTIDodge
Nov 7, 2007 01:52 PM
Spennyman
Bronco II
May 11, 2006 01:12 PM
