Ground Points
I am doing research, for my 1992 F-150 5.0 XLT, in an attempt to learn and apply as much information as possible to the restoration of my first truck. I am 100% an amateur and there is a lot of things I do not know/ understand about the technical side of automotive repair/engineering. With all that being said here is my question.
-Does anyone know a full list of names and/or locations for grounds points in a 1992 F-150 5.0 XLT?
-Can someone explain to me how and why they work?
Any information would be appreciated. Thank you.
Popular Reply
Attachment 277903
Attachment 277901
Attachment 277905
Attachment 277906
Basic function is to complete the electrical circuit for proper charging, voltage signals, etc. That is my short understanding.
Attachment 277903
Attachment 277901
Attachment 277905
Attachment 277906
There is also a ground clamp on the NEG battery cable half way to the starter or engine that is bolted to the frame for trailer towing.
The trailer plug also has a ground wire (white wire) going from the plug to the frame.
Note that the Ignition system is grounded inside the distributor.
You also have static ground straps for the radio from the engine to the safety wall and frame to the body at several locations.
I say this because my 81 F100 (4.9) has this as the factory main ground for the frame. Had 2 trucks this way and no trailer tow package.
Then trailer tow package wiring ground can go to the frame as the factory main ground from battery to motor or starter bolt did the frame also like you said.
I wired my trucks trailer light plug ground to the frame to pick up the trailer light ground.
I dont know of the newer trucks but the 80's also had grounds inside the cab on the firewall behind the dash.
Depending on early or late the 80's trucks had different tail light grounds.
There was also ground wire from motor to firewall (main cab ground?) and firewall to hood (told for radio noise?).
It will be said "you can never have enough grounds"
Dave ----
The frame ground clamp on the NEG battery cable was on all the OBS trucks if they had the tow package or not as the plate lamp used the frame for a ground if the truck did not have rear bumper.
In these trucks the frame does not have to be grounded as nothing uses it for ground unless you are pulling a trailer.
I thought by the 90's all pickup trucks had a rear bumper unless they were a C&C truck?
Where was the plate mounted if no rear bumper? Just like to know is all.
Dave ----
It looks just like this:
Also, I know the question was regarding trucks but the 92-96 Broncos also had a ground point behind the drivers tail light if the rear window has a defrost grid.
There are also braided ground straps in several locations but I don't believe these are considered "ground points"
