Window motor test
Old Dec 5, 2003 | 10:07 AM
66MercMan's Avatar
66MercMan
Window motor test
Does anyone know how to test power window motor without the switch? I got doors from a wrecker and I have tried to hook a battery up to them but I can't get them to move or make any noise. I wanted to see if they work before I buy a switch assembly and mount them on the truck. Any help would be great.
Thnkx, 66MM
Old Dec 5, 2003 | 11:51 AM
nuts4hotwheels's Avatar
nuts4hotwheels
Hooking a 12 volt power source to it should make it work. If not it is probably bad.
Old Dec 5, 2003 | 07:15 PM
hermangarza's Avatar
hermangarza
a computer AT power supply with a fuse
thanks
Old Dec 5, 2003 | 11:14 PM
locknkey's Avatar
locknkey
All it is , basically is a 12 v DC motor, it either can go either way, by the rocker switch, the switch controls the moment and if its out of time, will not work in the bracket...some even has a cut off relay switch to signal that the arm has reached its end and should stop....thats the way its design to work. Also some have to routed through the fuse for a certain amount of amps....15,to 25 or 30 amp...depending on how much the winding makes the motor run with a start booster in the motor housing. If the brushed has weak springs attached to the armature, no contact will result.
Old Dec 5, 2003 | 11:21 PM
85f-250-460's Avatar
85f-250-460
thanks
that a good one, I'll have to remeber that one
James
Old Dec 6, 2003 | 09:30 PM
hermangarza
ill tell you something else they work on reverse poliratity power to power and ground to ground make motor go up and power ground and power ground will make it go down. Have fun
thanks
Old Dec 6, 2003 | 11:13 PM
redneckdieselmechanic's Avatar
On another hand, does anybody know where i can get new power window switches? mine are burnt up
Old Dec 7, 2003 | 11:30 AM
hermangarza
radioshack has some dpdt switches that will nice but if you want original try a wrecking yard
Old Mar 16, 2006 | 10:52 AM
66MercMan's Avatar
66MercMan
Sorry to dig up an old thread, but I just wanted to thank Herman for his info. The reverse polarity is what was hanging me up, now I have my windows open. I shaved the door handles on my truck and I was sick of going through the back window every time I accidentally closed the door. Now that I'm working on the flair again I hope to have some pics up soon.
Old Mar 16, 2006 | 12:17 PM
hermangarza
you can also get the remote they sell in autozone the one that has 1234 buttons, they also work in monotary. 1 would be for up 2 would be for down, 3 would be for the second window up and 4 down.
thanks
Old Mar 16, 2006 | 01:08 PM
locknkey's Avatar
locknkey
NAPA carries some SPDT switches for windows and doors, abet high in cost, but well worth it to check out and get, I use an rocker switch (for gm) to make my windows go up or down in a non mortorize situation that wasn't designed for the roll up/down windows, useing a window motor from an old 77 monti carlo, next am going to have my roll doors move by themselves using an remote and a arm from an overhead garage door opener....
Methodical_1
18
Jun 12, 2018 08:50 AM
Krazyhorse93
Oct 14, 2016 02:00 PM
Kendal
May 10, 2016 12:50 PM
Dpan63
Apr 9, 2014 05:42 AM
mikeismadness
1978 - 1996 Big Bronco
21
Jul 27, 2011 02:29 PM
