Hi all, I recently put a 2" leveling kit in the front and installed new MOOG 3 and 1/4 degree cam adjustment kits on my 1993 F250 4x4 with front leafs. However, my camber is still slightly positive by about a degree or two when i have them maxed out. I'm not sure what to do from here or if they make larger cam kits. If anyone has any advice or what they did to fix their camber i would appreciate it. Thanks!
Was that the leveling kit you bought? If so where and who?
Either way, take them off.
Those springs will not work without using pivot point drop brackets. Your ball joints are already side loaded as it sits now, you wouldn’t want a lot more. If you do a search on here, lots of us have tried them, and every time you need drop brackets, or live with camber issues. Google Ford TTB, lots of threads on the subject.
