Fuel issues??
Old Apr 23, 2025 | 08:35 PM
1994F150351w's Avatar
1994F150351w
4wd Low
Fuel issues??
Good evening, just bought a 1994 F150 ext cab long bed 2wd with the 351W and automatic transmission. On the way home from buying it (4+ hour drive) we got horrible fuel economy and we were dumping black smoke out the exhaust. Im wondering what the problem is? It is a very clean truck with 218,000 on it, previous owner appears to have put in a whole new exhaust system, so I was thinking it could be a sensor not plugged in or something? The check engine light is on, and the temp gauge does not work. Not sure what the issue is.
Old Apr 23, 2025 | 11:40 PM
Prototypemech's Avatar
Prototypemech
If your check engine light is on, that means the computer has detected a problem and has stored a trouble-code.
You can retrieve the trouble code by using a paperclip.
Follow this tutorial
https://www.ford-trucks.com/forums/1...aper-clip.html
It's a waste of time and money to try to fix the truck without finding out why the computer is upset.
Sounds like you have a great truck that needs a few parts to get her in tip-top shape.
Kra_880
15
Feb 3, 2023 11:11 AM
mpd579
6.7L Power Stroke Diesel
Jun 10, 2011 07:13 AM
crazer42
Feb 12, 2009 04:12 PM
idylmoments
Nov 1, 2007 02:37 PM
scoutboy
Dec 18, 2004 10:02 PM
