Sponsored by: Real Truck
Ignition switch position
Old Apr 21, 2025 | 06:36 PM
texasft's Avatar
texasft
I have tried countless times to align the gear in the cylinder lock to the plastic actuator, and I can not get the truck to start. It will start when you unbolt the ignition switch and use your thumb to move the pin to start the truck. Any suggestions?
Old Apr 22, 2025 | 11:14 AM
Eman85's Avatar
Eman85
No clue. What truck are you working on? How far apart have you had it that you have the lock cylinder out and a gear?
Old Apr 22, 2025 | 03:37 PM
texasft's Avatar
texasft
2000 F350. I replaced the shifter tube, shaft, and lever. I put the lock cylinder in and it turn truck and accessories on, but no start.
Old Apr 22, 2025 | 03:40 PM
texasft's Avatar
texasft
2000 F350. I replaced the shifter tube, shaft, and lever. I put the lock cylinder in and it turns the truck and accessories on, but no start.
Barkin 40s
Dec 30, 2012 02:07 AM
Rusty_S
General Automotive Discussion
Oct 1, 2011 03:00 PM
rmalottwtes30
Dec 30, 2010 11:54 AM
bobbyb61b
Dec 27, 2010 06:31 PM
jrv
May 16, 2008 08:49 PM
