Sponsored by: Real Truck
Steering pull to the right
Old Jun 19, 2024 | 11:25 AM
cpye2's Avatar
cpye2
Greetings! Long time, no post... thankfully!
I went in for an alignment today and the technician said the alignment wasn't out. He noticed the pull to the right also when he drove the vehicle. I am now wondering what could be the culprit. Here is some background:
2001 F250 7.3L 4x4 Ext Cab, Manual locking hubs
Was pulling to the right before AND after:
Recent tire change and recent hub change
With or without hubs locked. With or without 4x4 on
Apply brakes doesn't seem to make a difference
Speeds don't appear to make a different (though you don't notice it as much as lower speeds).
It will always drift right without applying slight force to keep it straight
40k miles ago I had death wobble and replaced the shocks, axle seals, ball joints, tie rods, replaced the trac bar bushings, added a dual stabilizer, replaced the sway bars, brake calipers, brake pads and rotors...
Any suggestions are welcomed at this point....
Old Jun 19, 2024 | 11:54 AM
rvpuller's Avatar
rvpuller
Veteran: Coast Guard
Jack it up to make sure you don't have a brake dragging first, next rotate the tire with the spare or a rear tire.
Denny
Old Jun 19, 2024 | 12:06 PM
nydiver's Avatar
nydiver
A sticky / failing u-joint in the axle shaft can cause this
Old Jun 19, 2024 | 12:46 PM
99powerstrokedF250's Avatar
99powerstrokedF250
There's many causes to this, hard to say which it is. First and simplest test is to rotate the front tires, see if the problem stays put or goes to the other side.
As mentioned, a dragging brake or sticky/bad u-joint can do it. Improper tire wear can do this (though guessing since your alignment guy said everything is good the tire isn't worn funny?). You've done some ruling out on a bunch of other stuff.
It COULD be just the crown to the road. Try getting out on a multi-lane divided highway and run in the left lane, see if it changes to pulling left.
Generally speaking, you DO want the vehicle to pull slightly to the right if it pulls at all - if something happens it'll go off the road instead of oncoming traffic.
Old Jun 19, 2024 | 02:10 PM
Eman85's Avatar
Eman85
Did they give you an alignment printout with the settings? If so what is the caster left and right? I'd swap tires left to right in the front and of course set air pressure.
Old Jun 19, 2024 | 03:03 PM
cpye2's Avatar
cpye2
Yeah I have tested it on may different roads and grades.... It isn't as noticeable on some grades but still exists.
My first thought was a sticking caliper. I'll start there and save the U joint for last. Those things are not fun.
I recently went to a different set of tires. It was doing this before and after the tire swap.
Old Jun 19, 2024 | 08:47 PM
bajaphile's Avatar
bajaphile
Front axle u-joints should not have an affect - they should not be moving while in 2WD.
If me, jack up front and manually rotate tires. If not a brake drag, then I'd bet its the wheel bearing.
Old Jun 20, 2024 | 11:47 AM
Eman85's Avatar
Eman85
Caster adjustment is what makes the truck drive straight or pull. Generally doing an alignment a slightly higher caster setting on the right is what you shoot for to stop a vehicle from wandering to the right on crowned roads. What is the caster setting?
Old Jun 20, 2024 | 01:29 PM
MotoStu's Avatar
MotoStu
Just a quick point of clarification on this. A front u-joint can affect steering even when the axle isn't spinning. The joint has to articulate when the steering knuckles move right or left, so a joint that is stiff can cause issues. I agree, though, that something like that wouldn't necessarily cause it to pull one direction or the other, but would more likely affect steering input and wander.
Old Apr 22, 2025 | 11:05 AM
cpye2's Avatar
cpye2
Been doing some spring debris cleaning so time to get back to work on the truck. I replaced the driver side front caliper. Didn't help or hurt the pull to the right. Went to dump the trailer. After 50 miles or so, on my way home when I was braking down a hill at 50mph I got a pull to the left and a death wobble began pulling me to the left. This remained the rest of the way home on braking. Didn't seem to matter the speed. Mostly noticeable at speeds over 15mph. Didn't matter if I was turning right or left. Eventually I got to a straight shot and applied the brakes and it wobbled and pulled to the right more aggressively than the normal pulling. The wobble didn't begin until I was on my way back after 50 miles or so, and that one time braking seemed to be what set off the wobbling the rest of the way home when I was braking. I did experience this wobble prior to replacing the right front caliper.
10 years ago at 318k miles I rebuilt the entire front end down to the axle seals / ball joints. That was 40k miles ago. I don't really want to have to get that far into it, but I may have it coming to me.
Old Apr 22, 2025 | 02:18 PM
crashz's Avatar
crashz
The alignment was a year ago, you may be out again based on that. Need to check it all and re-assess. With 360k on the truck, it may be something you neglected to replace then. IE Springs, steering box etc.
Old Apr 22, 2025 | 03:45 PM
cpye2's Avatar
cpye2
My truck has leaf springs on the front and back. Not coil springs. My steering box may be whacked, I have never tampered with it. I was hoping I wouldn't have to during the life of this truck. I replaced everything mechanical on the front end 40k/10 yr ago and did tires / front hubs last year. So far a right front caliper this year, which was not the issue.
Ny current diagnoses includes constant pull to the right and a death wobble / pull to the left when braking. New brake pads and swapping the front left & right rotors may eliminate some things inexpensively and quickly. Thinking about taking the aftermarket steering stabilizer off for a test drive also.
brimart
Aug 29, 2016 06:01 PM
cpye2
129
Jan 10, 2016 08:09 PM
inspector747
Mar 24, 2015 10:10 AM
RRocket
Oct 12, 2009 08:28 AM
SNIPER168308
Jun 11, 2009 12:35 PM
