Old school F350 problem
Old Apr 21, 2025 | 07:44 AM
Fast Lap's Avatar
Fast Lap
3rd Gear
Post Old school F350 problem
This may be rather lengthy but here is what I got. 93 F350 7.5 gas. The truck was parked for a while. Replaced the fuel tank, fuel pump and fuel filter. Removed all injectors, soaked in Chemtool, hooked up to fuel pump with a pigtail and tested all of them. Re-installed with ne O-rings. Removed plenum re-sealed, re-installed. New plugs, cap, rotor button, wires. Old plugs looked horrible. Rewired TPS (something chewed the wires up) with new pigtail. Chased and repaired vaccuum lines. Even used smoke machine. No visible leaks, Good fuel pressure. Now the problem.........the truck will not accelerate, it spits, sputters and dies. Will not pull a hill. If you can get it going it runs fine just stutters when you accelerate. ANY IDEAS?
Old Apr 21, 2025 | 09:24 AM
jas88's Avatar
jas88
Test fuel pressure. I recently went thru 2 pumps on a truck I was repairing from sitting before I got one that worked properly. The first pump showed pressure at the tank, but it couldn't even push the gas up to the engine. The second pump did what you are describing, it showed good pressure at the rail and it idled fine, but it would not let the truck accelerate. Tested pressure good at idle, but when I goosed the throttle, the pressure dropped.
Old Apr 21, 2025 | 09:25 AM
1Butcher's Avatar
1Butcher
Codes? Fuel pressure? Assuming it's a SD system, how's the intake pressure sensor? Throttle sensor?
Old Apr 21, 2025 | 10:37 AM
Prototypemech's Avatar
Prototypemech
As 1Butcher said... Check codes and check fuel pressure.
Old Apr 21, 2025 | 03:56 PM
Fast Lap's Avatar
Fast Lap
3rd Gear
Thanks. I am going to check it but not sure if that will be the problem. I drove it on the interstate Saturday for the second time and it will run 80 no problem
Old Apr 21, 2025 | 04:01 PM
Fast Lap's Avatar
Fast Lap
3rd Gear
No codes. Its not OBD II so I will have to get my adapter but the check engine light is not on. Not familiar with an intake pressure sensor. Is that the MAP sensor? TPS had to replace the pigtail because something chewed the wires up. There was enough left to tell which wire went where but the color code on the new wiring is different. Fuel pressure is 30-40 psi
Old Apr 22, 2025 | 04:54 AM
manicmechanic007's Avatar
manicmechanic007
After you beat your head for a while and replace half the truck
Check the capacitors inside your processor
Might want to do that right now
Old Apr 22, 2025 | 03:32 PM
Scndsin's Avatar
Scndsin
You can go 80 but no acceleration.
SPOUT plug gone, wire cut, or computer can't advance timing.
jaygrindz
Apr 1, 2022 08:27 PM
jonestr57
May 28, 2019 11:06 PM
mrfixit1968
25
Aug 19, 2012 02:44 PM
chefddh
1966 - 1977 Early Broncos
Jan 30, 2005 05:33 PM
t0ny78
Mar 8, 2004 08:53 PM
