Fuel Issue??
Old Mar 29, 2022 | 07:43 PM
jaygrindz's Avatar
jaygrindz
Fuel Issue??
I recently purchased a 1992 Ford F-350 Dually 5.8L with a service rack. For the first month or two it has been running perfectly fine. Recently it has started to hesitate, stumble and misfire once warm, after about 5/6 hours of daily driving is when the problem comes about. If I pull over and stop at the gas station and add fuel, the problem goes away for a short time. I’ve also found that lightly applying gas helps relieve the issues. Any ideas of what I’m dealing with? Replaced ignition coil and cleaned throttle body
Old Mar 30, 2022 | 06:28 AM
rla2005's Avatar
rla2005
How old are the spark plugs, wires cap/rotor?
Has the fuel filter been changed recently?
Have you checked the fuel pressure at idle and under load?
Old Apr 1, 2022 | 08:27 PM
InspectorJames's Avatar
InspectorJames
I have chased the same issue on my 88 350 with a 460. I replaced all injectors, fuel pressure regulator, both pumps, fuel filter, distributor, ECM, control module, plugs, wires, all vacuum lines, all sensors and stalkedvagaun yesterday after about 300 mile of running fine. Tomorrow I am replacing the tank selector valve and gas caps. I know the selector valve has failed I am curious to see if this was the problem $3500 ago.
Time_Traveler
Feb 21, 2017 02:12 PM
BRiddoch
Jun 30, 2016 07:35 PM
Papasmithnc
1997 - 2003 F150
Sep 9, 2014 10:37 AM
vmlb
Oct 11, 2012 01:11 AM
spitfireal
Jun 14, 2006 03:25 PM
