Lifter tick ?
Old Apr 28, 2025 | 03:41 PM
  #46
F150 89's Avatar
F150 89
Originally Posted by 88n94
Sorry I can't help you with the extra power, I just like to leave engines stock. They will usually last much longer and be more reliable if left to operate the way the factory engineers designed them. Just my opinion.
all good i gotcha makes sense I’ll probly stay stock then want it as reliable as possible
Old Apr 29, 2025 | 12:58 AM
  #47
88n94's Avatar
88n94
Originally Posted by F150 89
Oh wow good catch didt even realize that that does look off I didt check for play but I will when I get home from work iv heard of flat tapper cams being slightly off center for the lifter to be able to spin but that looks off by a lot the one lob looks almost perfectly center but the bad one looks way off Mabey that’s what caused the lifter to fail ?
Yhoa I would see if the cam will move in the direction that moves the cam closer to the center of the hole. By sticking something like a large screwdriver in a lifter hole and prying on the cam lobe. The cam really shouldn't move back and forth, but if it does or not is a troubleshooting procedure.
Old Apr 29, 2025 | 02:09 PM
  #48
F150 89's Avatar
F150 89
So I checked the cam for movement and nothing it’s rock solid and when I look down the lifter bore it don’t look as bad as the camera is showing it it’s definitely not dead center but it’s within an 1/8 of an inch off center and they all seem that way still odd idk why it would be like that only other thing i have heard before was that some cams are off center to spin the lifters in the bore because if they were straight they wouldt spin idk tho idk how that off set would make them turn but just what iv heard before checked the push rod lengths also and everything seems to be in spec
Old Apr 29, 2025 | 02:53 PM
  #49
wwhite's Avatar
wwhite
@F150 89 Did you build the engine or did the machine shop, who assembled it?
Correct, lobes are not centered in the bore, the lifter is. This allows for the lifter to spin, I believe that lobes are not perfect shape either(to the naked eye, probably are), as this also helps to spin the lifters.
I think I asked near the beginning of this thread if the break in was done, you replied with 'NO'.
From what I know, you cam is garbage, and so are all the lifters as well. This is why people move to roller lifter/cams.
Either call your machine shop, or CompCams and get a recommended cam.
Old Apr 29, 2025 | 03:11 PM
  #50
F150 89's Avatar
F150 89
machine shop did the bottom end and cam i installed heads and valve train
Old Apr 29, 2025 | 03:12 PM
  #51
F150 89's Avatar
F150 89
and ya if new there was a different cam to use at the time I would went that route dumb machine shop recommended this one and ya u think that lobe is to bad to use it feels smooth and still has its shape u don’t think I can throw another lifter in and run it ?
Old Apr 29, 2025 | 04:06 PM
  #52
wwhite's Avatar
wwhite
Pretty sure it will grenade itself, just like the previous one did.
There is only one way to tell for sure.
By stopping when you did, you have saved the bottom end.
Throw another new flat tappet in there, you might not be so lucky.
What brand cam and lifters?
I'd call the manufacturer, let them know one was bad, let them know you haven't completed brake in procedure, and see what they say.
Old Apr 29, 2025 | 05:43 PM
  #53
F150 89's Avatar
F150 89
I don’t know the cam brand I’d have to call and ask again but the lifters rocker and push rods are Melling
Old Apr 29, 2025 | 11:00 PM
  #54
F150 89's Avatar
F150 89
here is the cam brand and specs do you know if this cam even works with speed density by chance
Old Apr 30, 2025 | 12:23 AM
  #55
wwhite's Avatar
wwhite
Nope, not for computer controlled, wrong cam shaft for your setup.
Old Apr 30, 2025 | 03:36 AM
  #56
F150 89's Avatar
F150 89
wow what a ****ty machine shop told the guy speed density to so now if I go back to stock cam do I need to change valve springs because this cam recommend valve springs on summit so does that mean there upgraded ones to strong for stock set up ? Also the push rods and rockers could I reuse them
Old Apr 30, 2025 | 08:02 AM
  #57
F150 89's Avatar
F150 89
do u think I should call the machine shop and make him replace it for getting the wrong one or bite the bullet it’s been about 5 months since he built it just found time to get it in the truck recently witch sucks but either way he ****ed up two times on the cylinder bore he went .60 over instead of .30 and now the cam
Old Apr 30, 2025 | 04:17 PM
  #58
F150 89's Avatar
F150 89
Sorry to keep blowing you guys up last question can I use this cam with speed density and can I use my stock rocker arms push rods and lifters and springs  for this cam ? Or the sell a Melling stock cam should I go with that instead ? Just wana put the biggest cam possible in with out messing with the computer and from my research this is the biggest I could go just worried it’s not going to worth with the rest of the stuff I have
Old Apr 30, 2025 | 05:03 PM
  #59
My4Fordtrucks's Avatar
My4Fordtrucks
Why are you looking at flat tappet camshafts?
Old Apr 30, 2025 | 05:06 PM
  #60
F150 89's Avatar
F150 89
I just figured that was the easiest route right now unless I can get around adding the spider in the valley and drilling and tapping for it and being able to find one but I thought I heard some one say I could get a kit with out the spider that uses the connected lifters but I couldn’t find a straight answer or the kit
