Lifter tick ?
Old Apr 21, 2025 | 11:27 AM
wwhite's Avatar
wwhite
Originally Posted by F150 89
seems like a valve/ lifter issue to me but everything is new is it common for new flat tapper lifters to be bad ?
Did you do a proper break in for the new cam and lifters?
If not, all that new stuff is junk, and that is where you are getting the noise from.
Old Apr 21, 2025 | 11:35 AM
F150 89's Avatar
F150 89
I attempted to but did have a few issue on the first start up with altornator failing then ignition module so it never ran 100% correct for the full 20 min brake in period I had to keep stoping and testing **** to work out all the bugs so I guess the answer would be no I was kinda thinking that also I’m gona tare into it and see what’s going on I don’t think ital go away on its own like other lifter tick this sounds to pronounce gona check cam and if all is good gona attempt to replace all the lifters on that side to rule them what do you think so good ?
Old Apr 21, 2025 | 03:18 PM
88n94's Avatar
88n94
I I don’t think ital go away on its own like other lifter tick this sounds to pronounce gona check cam and if all is good gona attempt to replace all the lifters on that side to rule them what do you think so good ?
That is a good idea. You SHOULD be able to tell if the cam is damaged by carefully looking at the bottom of the lifters. If the bottoms of the lifters look undamaged hope for the best. But I would definitely apply the special lube to the bottoms of the new lifters- they generally supply this lube with new lifters especially if you get a whole set. I would also pull the lifters on the other side and apply this lube.
This would be a good time to check the rocker arm to valve stem clearance especially on the side with the new lifters as they will be bled down. If you have a feelers gauge set that is what to use. In the absence of the instructions on which valves to check in a certain engine position, I believe you can place the engine at the firing position for each cylinder via the timing marks on the harmonic balancer. I can look up the specs for the clearance if I find my Haines repair manual.
Old Apr 21, 2025 | 04:28 PM
F150 89's Avatar
F150 89
ok sounds good should have apart during the week or on the week end and yes if u could get me the specs that would be awsome thank you guys so much for your time this trucks been kicking my *** with little issues I’ll keep u guys updated on what I find
Old Apr 21, 2025 | 04:34 PM
F150 89's Avatar
F150 89
One more question if I change my intake manifold to the Eddlebrock one will I need to retune the pcm as it’s speed density and what about long tube headers also will I need a tune if I upgrade these with a speed density computer
Old Apr 21, 2025 | 04:43 PM
My4Fordtrucks's Avatar
My4Fordtrucks
The intake isn’t the restriction so I would not be spending any money on the Edelbrock intake. How are you going to tune the computer?
Old Apr 21, 2025 | 04:46 PM
F150 89's Avatar
F150 89
I just figured since I’m pulling it off again wouldt hurt to upgrade the intake and headers and I don’t know how to tune but I would take it to some one that does if it needs to be tuned
Old Apr 21, 2025 | 06:46 PM
My4Fordtrucks
…but I would take it to some one that does if it needs to be tuned
Good luck finding someone that can do that. They were all over the place 30 years ago but not so much now. You should do upgrades that will work within the parameters of the SD system.
Old Apr 21, 2025 | 06:47 PM
F150 89's Avatar
F150 89
ya I figured that haven’t even heard of it being done tbh and do uk any that I could do off the top of ur head by chance
Old Apr 21, 2025 | 06:49 PM
My4Fordtrucks
No. You would have to buy an aftermarket tuner and figure it out on you own.
Old Apr 21, 2025 | 08:05 PM
F150 89's Avatar
F150 89
Ok gotcha thank you buddy appreciate ur time a lot new to this and trying to figure everything out
Old Apr 22, 2025 | 06:21 PM
F150 89's Avatar
F150 89
Quick question is this flang that mounts to the manifolds supposed to have those  lead rings in between the flanges  because the manifold looks like it has a built in ring already to seal against or am I wrong and have to add the lead rings to seal it properly wana make sure I have no leaks so when I fix the lifters I can be sure nothing should be ticking
Quick question is this exhaust flang that mounts to the manifolds supposed to have those lead rings in between the flanges because the manifold looks like it has a built in ring already to seal against or am I wrong and have to add the lead rings to seal it properly wana make sure I have no leaks so when I fix the lifters I can be sure nothing should be ticking
Old Apr 22, 2025 | 06:22 PM
  #28
F150 89's Avatar
F150 89
These are the rings I’m talking about
Old Apr 22, 2025 | 08:18 PM
  #29
My4Fordtrucks
No. The ball and socket joint does not use any gasket material.
Old Apr 23, 2025 | 05:47 AM
  #30
F150 89's Avatar
F150 89
Ok thank you
