Sponsored by: Real Truck
No interior lights when door opened
Old Apr 19, 2025 | 12:40 PM
larryb484's Avatar
larryb484
1st Gear
I’ve checked fuses and interior lamp relay
the door ajar is on when any door is opened . I hope this isn’t an instrument panel issue w/ battery saver relay. Any help is appreciated
Old Apr 19, 2025 | 12:45 PM
INFRNL's Avatar
INFRNL
you might want to let someone know what truck you are referencing....Also is it using ay door, only a certain door. How to you expect help if we have nothing to go on.
on something like a 7.3 or 6.0 it's usually a door switch. If it's a newer truck, could it be a setting, door switch....bulbs
Old Apr 20, 2025 | 10:54 PM
Vendguy's Avatar
Vendguy
8th Gear
Ok I apologize....it's a 2008 F350 5.4 ...if you open any door the light doesn't come on...only way to get on is to manually hit switch......
Old Apr 20, 2025 | 11:24 PM
INFRNL's Avatar
INFRNL
I'm not familiar with an 08. It there an option to disable the dome light when opening the doors? Im pretty sure this is an option for newer trucks but I'm not sure on yours. How long have you owned the truck and have they ever worked since owning? I'm trying to determine if this just started out of the blue or has been an issue
ithaca1230
Dec 17, 2018 07:50 AM
sbowling79
Nov 7, 2012 09:25 AM
dbaring
Mar 7, 2005 02:41 PM
jhornback
Electrical Systems/Wiring
Sep 11, 2003 08:48 AM
dorgan
Apr 23, 2002 04:23 AM
