Door ajar issue?
Old Mar 6, 2005 | 09:08 PM
dbaring's Avatar
dbaring
Door ajar issue?
When I open the doors, the door ajar light does NOT come on, and neither do the courtesy lights. I checked the fuses and relays, all looks good.
I read all the threads on this, and I WD-40'd all the door latches, etc, still does not come on. The lights themselves work fine, and if I take the cover off the relay and push the copper part of the realy together (to complete the circuit) all the courtesy lights come on.
Question - if one door ajar switch goes bad does it cause them ALL to fail? (or should I be able to tell which one is bad by just ONE door causing the Door AJAR light to NOT come on?)
If they all fail because one is bad - how then do I know which door is bad or do you have to replace them all?
Any help or troubleshooting steps would be greatly appreciated
Old Mar 7, 2005 | 12:37 AM
Monsta's Avatar
Monsta
Sit. Stay.
So maybe the relay is bad??
Old Mar 7, 2005 | 02:41 PM
fomoco_1's Avatar
fomoco_1
That would be my first guess too.
